Old 01-15-2020, 08:59 PM
David Jones's Avatar
Default Hybrid Valve Lash
Slowly, over the last week or so, I’ve been checking the lash on my hyd roller cam / solid roller lifter “hybrid”. It’s been a few years and about 2500 miles since last time. After a few evenings disassembly, I managed to get to the point where I actually checked a few tonight and probably could have saved the effort. I use .005 and so far they’ve been either .005 or .006. I have polished the valve covers and the fan and will put on new belts, so that’s a plus. A sore shoulder makes the process slow which can’t be a bad thing.
ID:	528901   Click image for larger version
ID:	528902   Click image for larger version
ID:	528903   Click image for larger version
Old 01-16-2020, 07:06 AM
steve25 steve25 is offline
Looks like your golden with little to no ware having taken place in 2500 miles.
Retorque the heads gaskets if you have not done so already and slap it all back together and enjoy.!
Old 01-16-2020, 11:05 AM
GTO TEX's Avatar
GTO TEX GTO TEX is offline
I too run a hybrid valve train. Over the last 4 years, I have only found one valve to be out by .001 which is probably where I set it a tad loose. I put about 3000-5000 miles a year on mine and check it annually while doing my other maintenance.
Mike Iden
'66 GTO Post/468, 700R4, 3.31 7.25@96mph 1/8
'21 Chevy 4X4 Crew RST Z71
Old 01-16-2020, 11:15 AM
Formulajones's Avatar
I wouldn't expect it to move unless something goes horribly wrong, especially with just 2500 miles, but always a good idea to periodically check and catch anything early.
One of our daily drivers is a solid flat tappet, and with just over 30k miles now the valve lash has been perfect with no change.
Old 01-16-2020, 12:52 PM
68lemans462's Avatar
68lemans462 68lemans462 is offline
I checked the valve lash on my solid flat tappet 455 and no adjustments were necessary after about 5k miles.
1968 Lemans. 37,000 original miles. GTO clone. 462ci/KRE 290 heads. UltraDyne 280/288 Solid/850 Qjet by Cliff/Performer RPM/TSP 9.5" in TH400/8.5" 3.42 gears/3950# Race weight/12.58@106 at Bandimere speedway high altitude
Old 01-16-2020, 01:21 PM
grandam1979 grandam1979 is online now
I’m confused how your running that tight of clearance and not having a issue? Are your checks hot, cold or both. Most solid rollers are recommended to be set .015 - .025 depending on the cam.
Old 01-16-2020, 02:05 PM
This a solid roller lifter (Crower 66260h) on a hyd roller cam (230/236 Comp). Tight is good.
Old 01-16-2020, 04:40 PM
How did you decide on .005 clearance?
Old 01-16-2020, 04:59 PM
Following what others had done and mfg’s recommendations.
Old 01-17-2020, 01:31 AM
Formula8's Avatar
Formula8 Formula8 is offline
I set mine at .005 and checked them at 500 miles and they were exaclty the same. Took the opportunity to open them to .006 and don't plan on checking them again for awhile.
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
The Following User Says Thank You to Formula8 For This Useful Post:
Old 01-17-2020, 09:13 AM
After this, I suspect that mine will remain unchecked for a good little while also. I finished the actual lash setting last night and my shoulder suggested that I leave it right there and go find the heating pad. I think I can have the rest of it put back together by sometime Saturday morning.
Old 01-17-2020, 10:00 AM
Cliff R's Avatar
Cliff R Cliff R is offline
Aside from the drama I had with the PRW stainless full roller rocker arms (having to check the lash a couple of times over a period of a few days until I discovered the rockers were worn heavily at the roller end where the pin goes thru them) mine have had three adjustments in 11 years. I just did one last week and none were over .006" and it's been quite a while since I checked them.
I check mine dead cold and have a Ford solenoid with a push button on it to make the job quick/easy. It takes longer to get the covers off than it does to lash the valves!......Cliff
Old 01-17-2020, 10:43 AM
On my street car I permanently wired in a KD tools 124 push button switch to my solenoid for easy lash settings and hot start issues before we had mini starters.
When not needed I stuffed it in small plastic Sandwich bag tied off closed and tucked it under the power brake booster.
It saved me from being stuck many times until I went the Ford remote solenoid route!
Thread Tools
Display Modes
