Old 01-18-2020, 06:51 PM
wbnapier wbnapier is offline
Default Vapor Lock - Danger
I've owned my tri-power GTO for 4 years. In that time, I've never had an issue with vapor lock. It always takes 5-7 seconds cranking on a hot start feathering the throttle to catch, but nothing too bad. Cold start no problems ever. Once I'm moving, no problems with vapor lock.
This last month, including today's cruise, it will hot start after some cranking, but will die one or two times in the first 1-2 minutes of idling/driving.
So, I was rolling out of a parking lot and trying to merge into heavy SoCal traffic and it is sputtering and dies. Not safe at all.
Again, once I'm cruising and fuel is moving, no problem. Cold, no problem. WOT, no problem.
I have a 5/16" feed fuel line to a mechanical pump. No return. The fuel line and filter are NOT in contact with the block. I have phenolic insulators under the carbs.
Using the temperature gun, the exterior of the fuel bowls is 140-160F.
The engine runs cool, <180F. The ambient temp is cool, maybe 65F. Dual electric fans, both functioning. 160F thermostat. The cooling system is beautiful.
My next move is to buy a filter with a ¼" return nipple, and run a rubber line back to the tank. I'll need a new sending unit with ⅜" feed and ¼" return, and use a reducer on a piece of rubber hose at the tank to go from ⅜" to 5/16" existing line.
Question, did something change in California gas? Anyone else suddenly having issues? I can't understand why now...
1965 Pontiac GTO
455/469 w/ #48 Heads, '65 Tri-Power
9.25:1 CR
Stump Puller Cam
Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00
3.55 Rear Differential
Front: 225/60R15 Height: 25.6"
Rear: 275/60R15 Height: 28"
Old 01-18-2020, 07:31 PM
Scott65's Avatar
Scott65 Scott65 is offline
Have you checked the vent lately? Could be collapsed or plugged.
Old 01-18-2020, 07:34 PM
No, I have not. Good call on that. I will check it out and report back.
1965 Pontiac GTO
9.25:1 CR
Stump Puller Cam
Old 01-18-2020, 07:40 PM
Scott65's Avatar
Fingers crossed its that simple.
Old 01-18-2020, 08:32 PM
carbking's Avatar
carbking carbking is offline
From the troubleshooting section of my website:
http://www.thecarburetorshop.com/Tro...ardstarthot://
Jon.
Old 01-18-2020, 11:05 PM
Richie Hoffman's Avatar
Richie Hoffman Richie Hoffman is offline
try putting heat insulators under carbs
2008KRE Q16 Winner
2014 atco raceway doorslammer winner 86 grand am tube car 8.95 @152 455 eheads solid flat tappet cam
Hoffman Racing building and racing Pontiacs for 35 years
Old 01-18-2020, 11:49 PM
tom s tom s is offline
Richie,he has them!Tom
Old 01-19-2020, 12:26 AM
Stripes's Avatar
Stripes Stripes is offline
Spent a lot of time on this. Gas starts to boil at 95F and your fuel pump eventually is 160+f. Try the ceramic insulator that Canton sells that goes between fuel pump and timing cover. I ultimately solved my issue with a in tank electric fuel pump and a regulator at 6 psi.
Old 01-19-2020, 12:27 AM
Stripes's Avatar
Canton Racing Mechanical Fuel Pump Insulators 85-010
Old 01-19-2020, 02:52 AM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
Installing a return line is a good idea but I'd use a reproduction A/C 1/4" steel tube instead of rubber hose all the way back. You'll have to change out the sending unit in the tank or solder in a hose nipple to accommodate the return line.
Yeah, CA gas sux. That was the main reason for installing EFI in my '66 GTO.
Old 01-19-2020, 07:36 AM
steve25 steve25 is offline
It may not be vapid lock, you now may have some bad rubber fuel line that's dry rotted and leaking air which the fuel pump draws in much much faster then fuel.
Old 01-19-2020, 11:03 AM
Formulajones's Avatar
Formulajones Formulajones is online now
We use the same suppliers for gas here in Arizona, same crappy 91 octane.
As it stands right now I haven't noticed any issues on our cars. We daily 2 classics and both have been fine. One has a return line fuel system and the other does not. Temps have been hovering close to 60 up here in Prescott and 70+ in Phoenix and I've made the trip (220 round trip) with both cars recently without issues with fuel, filling up at different stations.
With that said it could be a number of different issues causing problems. Could just be you got a bad tank of gas recently. One thing I've noticed is that the ethanol content is not consistent from one station to the next. Installing a return line certainly helps and not a bad idea to do so. This fuel does not like temperature AT ALL. Sounds like you have all the other bases covered.
Old 01-19-2020, 12:55 PM
OG68 OG68 is offline
May have been the change from summer to winter blend fuel although that happened a few months ago.
2007 Cadillac SRX
Old 01-19-2020, 02:49 PM
1965gp 1965gp is offline
If you didn’t have a problem before, I would think that something is failing.
I had a very similar problem on my 70 GTO and a new fuel pump took care of it. I believe the ethanol gas deteriorated the rubber seal.
Old 01-19-2020, 04:25 PM
The problem has been going on for 1-½ months.
The carb vent is clear.
I'm ordering the Canton fuel pump insulator from Jegs, and the fuel filter with a return provision from Pontiac Tri-Power.
https://pontiactripower.com/collecti...th-return-line
Regarding the return line, do you recommend buying a pre-bent one, or bending my own? The Right Stuff has a pre-bent one, but I have no experience with those.
Going for a test drive now...
1965 Pontiac GTO
9.25:1 CR
Stump Puller Cam
Old 01-19-2020, 04:56 PM
Scott65's Avatar
I should've been more clear, I was talking about the tank vent. I assume you have the small metal line on the tank with the short section of hose. That could be rotten, or have debris in it.
Old 01-19-2020, 06:33 PM
I'll check the tank vent. I replaced the vent hose about 2 years ago, so I think it is OK. Also, if I had tank venting issues, I would expect the issues all the time, not just after hot starts... I will check though.
1965 Pontiac GTO
9.25:1 CR
Stump Puller Cam
Old 01-20-2020, 03:03 AM
Stripes's Avatar
The pre-bent lines fit well and save time.
Old 01-20-2020, 08:16 AM
chrisp chrisp is offline
Absolutely / happens quite often years after the build one needs to go & tighten all clamps & possibly replace the rubber hose ends .
Old 01-20-2020, 01:14 PM
Symptoms posted remind me of a 2bbl carb that the base plate to fuel bowl screws have worked their way loose.
That or a carb that's right on the verge of loading up. Not enough to flood over but enough to cause stumble when turning or crossing unlevel pavement at idle or minimal throttle opening.
Homework before part swapping. Including basic engine tune
Clay
