Old 01-19-2020, 05:48 PM
JLuger's Avatar
JLuger JLuger is offline
Default 350 or 455?
Looking for opinions . I have a 66 project Goat that nds a motor, came across 2 and can't decide what one to go with this is a back burner kinda driver project, both are Pontiac's one is a 68 350 bored 30 cam a little head work with a edelbrock intake probably 10k on it. Other is a 73 455 with a stock rebuild 15-20k on it. The 350 comes with all the accessory pulleys, alt etc. that I nd 455 is just motor.
Both run good $1200 apiece. My car is a m22 with 3.55's I'm leaning towards the 350 thoughts?
Old 01-19-2020, 05:52 PM
70gtojosh 70gtojosh is offline
You can't install a smaller engine than what the car came with originally.
Old 01-19-2020, 06:04 PM
David Jones's Avatar
At some point, it’ll be a front burner project, either for you or someone else. 455.
Old 01-19-2020, 06:13 PM
JLuger's Avatar
Am I correct in thinking hp would be close on both. Seeing as the 350 is built a little compared to the stock 455?
Old 01-19-2020, 06:36 PM
ANDYA ANDYA is offline
A 350 can be made to run pretty strong, BUT I would never put one in a real GTO. For me it would have to be a 389 or larger. I think most GTO enthusiasts would feel the same way.
Old 01-19-2020, 06:38 PM
t money t money is offline
455. There getting harder to find making them more valuable so it likely add value to the car if resold.
Old 01-19-2020, 07:03 PM
67gtospud's Avatar
67gtospud 67gtospud is offline
455. When it comes down to it they cost about the same to build. You can probably knock the guy down a little on the 455 since it’s missing parts. You’ll thank yourself later for the 100 extra cubic inches later. Power wise the 455 has more potential per $$$ and will be more fun on the street with the torque it makes effortlessly.
1967 GTO, 432 (428+.030), 4-bolt mains, factory Nodular crank, scat rods, icon dished pistons, Lunati HR 243/251@.050, .618/.622 lift, Edelbrock 72cc round port heads, 10.5:1, offy 2-4 intake, Edelbrock 650cfm carbs, Super T10 trans (2.64 first), BOP 10 bolt w/ Eaton posi and 3.36 gears
Old 01-19-2020, 07:35 PM
mgarblik mgarblik is offline
Yes, horsepower may be about the same. However, horsepower is just a calculated figure: torqueXRPM/5252. Torque is real and that's what moves the car. You will be down 40% with that wimpy 350 vs a 455. Torque is what made Pontiac special and not just a much prettier Chevy. Also, as mentioned, a 350 engine in a real GTO would move it into the "not interested" zone at sale time for many Pontiac people.
Old 01-19-2020, 07:56 PM
JLuger's Avatar
Well I'm listening glad I posted the question I was talking myself into the 350 but really thought the 455 was the way to go.. I was told it was a 71 455 but when I checked it out it was a 73 YC with 4 X heads and stock intake. Not sure of internals and that kinda turned me off. I had a better idea what was in the 350. What's the chances the crank is drilled in the 455 for pilot shaft bushing.
Thanks for all the replies.
Old 01-19-2020, 08:16 PM
4dblnkldude's Avatar
455 fo sho!!!
Old 01-19-2020, 08:33 PM
1965gp 1965gp is offline
Even if it is a stock motor I would go with the 455.
Interestingly enough- I was in the same boat. I have a 66 GTO I am building and the motor was pretty worn and was mixing oil and water. I didn’t want to build a new motor, but after seeing how worn the motor was it was going to need to be replaced. I picked up a strong 350 that dynod 275 at the wheels in a 73 Firebird. The motor in the car had already been bored .60 over.
After asking for lots of advice, it was pretty obvious that I was better off building a spare 400 I had over using the built 350. The 400is at the machine shop now getting a pretty much stock rebuild with a Tri-Power cam.
Old 01-19-2020, 08:39 PM
tom s tom s is offline
If your going to sue the M22 you will forsure want the 455.Tom
Old 01-19-2020, 08:43 PM
F ROCK's Avatar
F ROCK F ROCK is offline
It's not; but there is a hole there, and you can turn a bushing down to fit in there.
My 350P ran great. Buy them both lol. 350's are great for backup while you're building something.
The Following User Says Thank You to F ROCK For This Useful Post:
Old 01-19-2020, 08:49 PM
Good call. I have two running 350’s on stand by. I think I paid $300 for the last one.
Old 01-19-2020, 08:50 PM
Hikin Mike's Avatar
There's no replacement for DISPLACEMENT.
455.
- Mike
Old 01-19-2020, 09:06 PM
JLuger's Avatar
Bummer on the crank not being drilled. Okay I'm going to go with the 455!!!!
Old 01-19-2020, 09:24 PM
67gtospud's Avatar
It might be but you won’t know for sure until you measure it or try to drop a bearing or bushing into it. As meantioned; if it’s not already turned to size you can just turn a bushing down to fit.
Old 01-19-2020, 10:39 PM
77 TRASHCAN's Avatar
350’s generally can not be given away...
455 is only choice, hope it works out for you!!!
Might offer the seller, maybe $100.00 for the pulleys and brackets off the 350.
Shut it off
Shut it off
Old 01-19-2020, 11:12 PM
After all the 455 and 400 engines are gone we’ll all be running 350s.
Fortunately that day hasn’t arrived yet.
Old 01-19-2020, 11:24 PM
Assuming any are left, Bart. 350Ps get scrapped at an alarming rate.
Dr. Thomas Sowell
