Old 07-11-2022, 03:51 PM
lemans67 lemans67 is online now
Default What gets sealed on a convertible?
I know the top windshield header gets caulking. What else on the convertible trim gets sealed? A pillar panel?
67 LeMans convertible. Tyrol blue, M22z autogear, 2.73 8.5, 455, FAST MPI fuel injection. 243/ 251 112. solid roller. SD performance ported 6x heads.
Old 07-17-2022, 06:30 PM
geeteeohguy's Avatar
The only real caulking is to hold the windshield in place. The top seals to the header with a rubber weatherstrip, and uses rubber weatherstrips to seal at the A pillar and at the tops of the windows.
Jeff
Old 07-18-2022, 07:05 AM
Jeff Hamlin's Avatar
The windshield Top Molding and end caps as well as the A-Pillar trim had a Dum Dum type sealant.
This can be found in various widths and thicknesses
As mentioned it's not a "Caulk" per se more of a pliable sealant putty in tape form.
Name:	66-67 A-PILLER TRIM.jpg
ID:	594546   Click image for larger version
Name:	66-67 CONVT WINDSHIELD TOP TRIM.jpg
Old 07-18-2022, 08:36 AM
Ok. Those are the pieces I was thinking that got sealant. Just double checking. I have the 3M strip caulk. Thanks
