17058240 Q-jet
Does anyone have the specs for this carb? I'm curious to know what the stock air bleeds, jets/rods etc are... Thanks!
I guess I'll try this again... Anyone??
#17058240 uses #72 jets, pri. rods stamped 53P, sec. rods stamped CP.
Here is the "recipe" for the 1976 vintage, besides the jetting i guess your carb is similar if not exactly like this?: Carb # 17056240 jet 75 prim.rod 49K idle channel .058 idle tube .032 upper idle air .059 lower idle air .080 idle air bypass .100 idle discharge .070 main air horn .050 main air body .045 main air nozzle .054 sec rod / hanger DB / I sec acc. / pri. acc. .054 / .033 sec air tube / Fill .025 / .038 Hope this helps some.... |
Yes it does.. Thanks
