Old 01-10-2020, 08:02 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Originally Posted by LiL Jack View Post
BES got 430cfm out of a set of Super Chiefs.
Never had any issues with them.
Made 950 HP with a baby cam on a 535 with a tiger intake.
1000 would be easy with a little more intake work and can.
Didn't Bruce M make a 1030 hp or so?
Go fast, see Elvis!
Old 01-10-2020, 08:12 PM
Stan Weiss's Avatar
I have a set in my cylinder head chart. But wanted to make sure that those numbers were really correct. So I check with Larry Meaux and got which more than just a yes.
Stan
Thursday , August 18, 2005 3:04:49 PM JC Culpepper
Pontiac alum Head (Wenzler) 2.350/1.810 55 deg seats
4.380 Bore HeadGasket 4.380x4.500 No-Pipe
13.75/14.0/45.0 Int=1.575x2.750=4.331
77.0 % with Pipe at .900 Lift Exh=2.025x1.825=3.696
STP=1.275 .86I/.866E
Intake Valve OD= 2.350 Valve Area= 4.3374 .25 L/D Ratio= 0.5875
Exhaust Valve OD= 1.810 Valve Area= 2.5730 .25 L/D Ratio= 0.4525
Intake Exhaust Intake Exhaust Intake Exhaust Intake Exhaust
Valve L/D L/D Valve Valve Curtain Curtain Curtain Curtain
Lift Ratio Ratio CFM/In CFM/In Area Area CFM/In CFM/In
0.200 0.0851 0.1105 35.63 54.74 1.477 1.137 104.66 123.86
0.300 0.1277 0.1657 50.44 71.50 2.215 1.706 98.78 107.84
0.400 0.1702 0.2210 64.08 86.10 2.953 2.275 94.11 97.40
0.450 0.1915 0.2486 70.35 3.322 91.84
0.500 0.2128 0.2762 76.62 97.88 3.691 2.843 90.03 88.58
0.550 0.2340 0.3039 82.34 4.061 87.96
0.600 0.2553 0.3315 86.16 107.00 4.430 3.412 84.37 80.70
0.650 0.2766 0.3591 89.25 4.799 80.67
0.700 0.2979 0.3867 92.13 114.30 5.168 3.980 77.33 73.89
0.750 0.3191 0.4144 94.09 5.537 73.71
0.800 0.3404 0.4420 96.05 118.61 5.906 4.549 70.54 67.09
0.850 0.3617 0.4696 96.57 6.275 66.74
0.900 0.3830 0.4972 97.18 119.44 6.644 5.118 63.44 60.05
0.950 0.4043 0.5249 97.70 7.014 60.42
1.000 0.4255 0.5525 0.00 0.00 0.000 0.000 0.00 0.00
Intake Effect Valve Curtain Curt Exhaust Effect Valve Curtain Curt
Valve Flow CSA Area Area Area Flow CSA Area Area Area
Lift Coeff. Area FPS FPS Coeff. Coeff. Area FPS FPS Coeff.
0.200 0.244 1.059 85.51 251.18 0.717 0.375 0.965 131.39 297.26 0.849
0.300 0.346 1.499 121.06 237.08 0.677 0.490 1.260 171.60 258.83 0.739
0.400 0.439 1.904 153.78 225.87 0.645 0.590 1.518 206.63 233.76 0.667
0.450 0.482 2.091 168.83 220.42 0.629
0.500 0.525 2.277 183.89 216.07 0.617 0.671 1.725 234.90 212.59 0.607
0.550 0.564 2.447 197.63 211.10 0.603
0.600 0.590 2.560 206.79 202.48 0.578 0.733 1.886 256.80 193.67 0.553
0.650 0.611 2.652 214.20 193.60 0.553
0.700 0.631 2.738 221.12 185.58 0.530 0.783 2.015 274.32 177.33 0.506
0.750 0.645 2.796 225.82 176.89 0.505
0.800 0.658 2.854 230.52 169.29 0.483 0.813 2.091 284.67 161.02 0.460
0.850 0.662 2.870 231.76 160.18 0.457
0.900 0.666 2.888 233.24 152.25 0.435 0.818 2.106 286.66 144.13 0.411
0.950 0.669 2.903 234.48 145.01 0.414
1.000 0.000 0.000 0.00 0.00 0.000 0.000 0.000 0.00 0.00 0.000
Intake Exhaust Exh/Int Exh/Int Minimum Normal Maximum Minimum Normal Maximum
Valve Flow Flow Flow % Curtain HP for HP for HP for HP per HP per HP per
Lift CFM@28 CFM@28 Ratio FPS Rat 8 Cyl. 8 Cyl. 8 Cyl. Cyl. Cyl. Cyl.
0.200 154.5 140.9 91.2 118.3 317.7 358.5 395.6 39.7 44.8 49.5
0.300 218.8 184.0 84.1 109.2 449.8 507.6 560.1 56.2 63.4 70.0
0.400 277.9 221.5 79.7 103.5 571.4 644.8 711.5 71.4 80.6 88.9
0.450 305.1 627.3 707.9 781.1 78.4 88.5 97.6
0.500 332.3 251.8 75.8 98.4 683.3 771.0 850.8 85.4 96.4 106.3
0.550 357.2 734.3 828.6 914.3 91.8 103.6 114.3
0.600 373.7 275.3 73.7 95.6 768.4 867.0 956.7 96.0 108.4 119.6
0.650 387.1 795.9 898.1 991.0 99.5 112.3 123.9
0.700 399.6 294.1 73.6 95.6 821.6 927.1 1023.0 102.7 115.9 127.9
0.750 408.1 839.1 946.8 1044.8 104.9 118.4 130.6
0.800 416.6 305.2 73.3 95.1 856.5 966.5 1066.5 107.1 120.8 133.3
0.850 418.8 861.1 971.7 1072.2 107.6 121.5 134.0
0.900 421.5 307.3 72.9 94.7 866.6 977.9 1079.1 108.3 122.2 134.9
0.950 423.8 871.2 983.1 1084.8 108.9 122.9 135.6
Avg.= 349.7 247.5 70.8 Max Intake Flow CFM= 633.07 Exhaust Flow CFM= 375.56
Saturday , April 1, 2006 J C Culpepper Wenzler Pontiac
2.350/1.780 Valves 50 degree Seat Angles
4.500 Bore Flow Fixture w/Radius Entry No-Pipe on Exhaust Ports
Valve Depths=.382I/.384E
14.5/16.0/30
Exhaust Valve OD= 1.780 Valve Area= 2.4885 .25 L/D Ratio= 0.4450
0.200 0.0851 0.1124 30.72 50.09 1.477 1.118 90.24 111.44
0.300 0.1277 0.1685 47.26 77.19 2.215 1.678 92.55 114.50
0.400 0.1702 0.2247 62.80 100.35 2.953 2.237 92.24 111.63
0.450 0.1915 0.2528 71.07 3.322 92.79
0.500 0.2128 0.2809 78.35 116.98 3.691 2.796 92.06 104.12
0.550 0.2340 0.3090 85.25 4.061 91.07
0.600 0.2553 0.3371 90.89 127.28 4.430 3.355 88.99 94.40
0.650 0.2766 0.3652 94.71 4.799 85.60
0.700 0.2979 0.3933 98.52 132.42 5.168 3.914 82.69 84.18
0.750 0.3191 0.4213 97.90 5.537 76.69
0.800 0.3404 0.4494 97.90 135.17 5.906 4.474 71.90 75.19
0.850 0.3617 0.4775 99.24 6.275 68.60
0.900 0.3830 0.5056 99.66 136.54 6.644 5.033 65.05 67.51
0.950 0.4043 0.5337 0.00 0.000 0.00
1.000 0.4255 0.5618 0.00 0.00 0.000 0.000 0.00 0.00
0.200 0.210 0.913 73.73 216.58 0.618 0.343 0.854 120.21 267.46 0.764
0.300 0.324 1.404 113.43 222.13 0.634 0.529 1.316 185.25 274.79 0.784
0.400 0.430 1.866 150.73 221.38 0.632 0.687 1.711 240.83 267.92 0.765
0.450 0.487 2.112 170.58 222.70 0.636
0.500 0.537 2.328 188.03 220.94 0.631 0.801 1.994 280.76 249.88 0.713
0.550 0.584 2.533 204.61 218.56 0.624
0.600 0.623 2.701 218.13 213.59 0.610 0.872 2.170 305.46 226.55 0.647
0.650 0.649 2.814 227.30 205.45 0.586
0.700 0.675 2.928 236.46 198.45 0.567 0.907 2.258 317.81 202.04 0.577
0.750 0.671 2.909 234.97 184.06 0.525
0.800 0.671 2.909 234.97 172.56 0.493 0.926 2.304 324.40 180.45 0.515
0.850 0.680 2.949 238.19 164.63 0.470
0.900 0.683 2.961 239.18 156.13 0.446 0.935 2.328 327.69 162.03 0.463
0.950 0.000 0.000 0.00 0.00 0.000
0.200 133.2 124.6 93.5 123.5 274.0 309.1 341.1 34.2 38.6 42.6
0.300 205.0 192.1 93.7 123.7 421.5 475.6 524.8 52.7 59.4 65.6
0.400 272.4 249.7 91.7 121.0 560.1 632.0 697.4 70.0 79.0 87.2
0.450 308.3 633.8 715.2 789.2 79.2 89.4 98.6
0.500 339.8 291.1 85.7 113.1 698.7 788.4 869.9 87.3 98.5 108.7
0.550 369.8 760.3 857.9 946.6 95.0 107.2 118.3
0.600 394.2 316.7 80.3 106.1 810.5 914.6 1009.2 101.3 114.3 126.1
0.650 410.8 844.6 953.0 1051.6 105.6 119.1 131.5
0.700 427.3 329.5 77.1 101.8 878.6 991.4 1094.0 109.8 123.9 136.7
0.750 424.7 873.1 985.2 1087.1 109.1 123.1 135.9
0.800 424.7 336.4 79.2 104.6 873.1 985.2 1087.1 109.1 123.1 135.9
0.850 430.5 885.0 998.7 1102.0 110.6 124.8 137.7
0.900 432.2 339.8 78.6 103.8 888.7 1002.8 1106.6 111.1 125.4 138.3
Avg.= 351.8 272.5 77.5 Max Intake Flow CFM= 633.07 Exhaust Flow CFM= 363.21
Pontiac Pump Gas List
Old 01-10-2020, 08:23 PM
slowbird's Avatar
slowbird slowbird is offline
Have they even done what you did your your High Ports ? You are starting threads just to control the conversation. Who in their right mind is going to spend 3500$ on a high end port job only to have issues when they can just choose a more solid head ?
You have a high end set of Barton High Ports.
You have a high end set of Barton Pro Ports.
You have a set of high end set of Tiger 2s.
I bet you have enough money in those 3 sets to buy a 3 bed, 2 bath 2000sq foot home in Arkansas. And you are going to "bracket race" your Tiger 2 engine ?
My post that Super Chiefs are soft is valid. So do what you do with the new "circle" and rip away.
You have no clue, you assume a ***** load of stuff!! But correcting your assumptions is a complete waste of time so you may continue being an idiot.
I would like to know how starting this thread im controlling who can post. That's a new one
Old 01-10-2020, 09:00 PM
PAUL K's Avatar
There is a thread in the Club House about this.
Go fast, see Elvis!
Old 01-10-2020, 09:15 PM
slowbird's Avatar
Clearly he learned from it lol.
Never seen someone so hell bent on staying misinformed. But i guess it works for him
Old 01-10-2020, 09:18 PM
slowbird's Avatar
Stan
14.5/16.0/30
Here is the thread from that head, was a nicely done head
http://forums.maxperformanceinc.com/...d.php?t=457762
Old 01-10-2020, 09:46 PM
Scott Roberts Scott Roberts is offline
I'm willing to listen to his firsthand info about the sc heads....
So Dcar, tell us about your sc"s and the issues you had with softness?
Seems others are making laps with a blower motor without issue.... so please, enlighten us with your firsthand info...
Old 01-10-2020, 11:45 PM
Are you talking heat treating like AP does with their IA2A solid ? How does chemical aging work ?
Aluminum is “aged” through either thermal induction or chemical treatment to induce hardening. Any heat treating company familiar with aluminum has the required furnaces to accomplish the task. Let’s look at 356T3 for instance. 356 is the alloy number; T3 indicates the aluminum was artificially “aged” to the T3 standard. ALL aluminum is T1 before “aging”. The normal heating/cooling cycles are what age aluminum. A wise builder will anneal any aluminum component BEFORE welding or machining it to insure uniform “aging” and hardness.
Dr. Thomas Sowell
Old 01-11-2020, 12:05 AM
slowbird's Avatar
Lil Jack do you remember many details of that build? Cam size, valve sizes used, anybidea if bes digitized the ports?
Old 01-11-2020, 12:35 AM
opeliac opeliac is offline
OK, can we get a final answer on the heads?
Does anyone have a CNC program for them?
Can they handle 2000+boosted HP?
Old 01-11-2020, 01:11 AM
GTOGEORGE's Avatar
Jim has to be around 1,500+ with his blown tempest!
GTO George
Old 01-11-2020, 12:03 PM
65nss4spdGTO's Avatar
65nss4spdGTO 65nss4spdGTO is offline
I’m a huge fan of the KRE HP head.
That being said, valve height and angle of the SC head by design has the potential to make more power if the port work is developed properly. I doubt a CNC program is available since at the time these heads were produced, CNC was just starting to become mainstream.
With the cost of duplication today, it may be a good option if someone has a great head to copy as the cost to develop from scratch will not pay the return.
Calvin Hill
Hill Performance
708-250-7420
Old 01-11-2020, 02:39 PM
tom s tom s is offline
Calvin,what were Ric and Dave Johnson running with the first gen heads in N/SS at 7 lb per CI,I seem to remember they were running high 8s?Tom
Old 01-11-2020, 02:52 PM
PAUL K's Avatar
Dave ran bottom nines high eights with
Wenzler II heads.... Hopefully Calvin remembers what Rick ran.
Go fast, see Elvis!
Old 01-11-2020, 04:19 PM
J.C.you's Avatar
J.C.you J.C.you is offline
Stan, ...Yeh, my old SCs. Still have them. Did some more work to them after the last time on the bench at Meauxs. Plan on running them this spring.
1966 GTO dragcar
1966 GTO Ragtop
1969 Tempest ET clone street/strip
1969 GTO Judge RA lll, auto
1969 GTO limelight Conv. 4speed go and show (sold)
1970 GP SSJ
1972 GTO 455 HO, 4 speed, (build)
Old 01-11-2020, 04:21 PM
Hooter's Avatar
Hooter Hooter is offline
Rick has been running the Wenzler 2 heads also. Hoping he get the new bullet out this year with the Warp 6’s. Should run pretty good with all of his car changes.
67 Bonneville ragtop
Old 01-11-2020, 04:30 PM
PAUL K's Avatar
Question
I talked to him at Norwalk and he filled me in on his build. It will definitely Bad Azz and I encouraged him to git'r done. None of us are getting any younger.
Go fast, see Elvis!
  #38
Old 01-11-2020, 04:37 PM
PAUL K's Avatar
Hi JC, did you ever get to dyno those heads or run them down the track? ..... They seem like they have a bunch of potential.
Go fast, see Elvis!
  #39
Old 01-11-2020, 07:28 PM
catalina_dream's Avatar
catalina_dream catalina_dream is offline
Default Best Pass for RJ
I believe that Rick's best was 8.80 @ 153
1972 Firebird
462, 6X heads, RA4 cam, iron intake, Cliff's Q-Jet
3925 race weight
Best of 12.88 @ 105 so far
  #40
Old 01-11-2020, 07:31 PM
mgarblik mgarblik is offline
The OP might want to call Heads Up Cylinder Heads in Dayton OH. It's been many years ago but Dave Layer, (owner RIP), had a program for them because I remember seeing a head in the Haas Machining Center. Randy Brewer is the new owner of the business and may have the old programs. Worth a phone call: 937-431-5555.
