66-67 frame
I need a clean frame for a 66-67 tempest le mans or GTO really looking for wagon frame but the only difference is the rear box so I can use anything prefer in northeast
When you really do something right it's like you didn't do anything at all 1931 Pontiac 5 window coupe OHC6 powered 2015 GMC Yukon SLT |
Hi
I have a 67 front clip
cut over 4" back on the rocker rail doubt it helps but ... |
Thanks but I am looking for a whole frame
Chris , PM sent Don
frame
Not sure what a wagon uses, but are you looking for a GTO hardtop or convertible frame> Hardtop doesn't have a closed frame even in back.
I do believe that Wagons use a ‘Boxed’ Frame
Dave - GTO3DEUCES |
frame
66 and 67 frames are not the same. 67 has 2 different convertible frames. Auto and MT. Crossmember bracket is welded in two different locations due to the introduction of the turbo 400 transmission. I do have a rustfree, pitfree CA 67 frame. Would need to check which one. Price $1500
I was just going by the Paul Zazarine ‘GTO Bible’; but your right, it doesn’t speak to Wagons...
frame
So is the front crossmember
67 frame
the FRONT crossmember or the TRANSMISSION crossmember???
Front crossmember, stamped slightly different, there were minute changes in these nearly every year. Transmission crossmember for convert & HD frame option Pontiac A-body is different than one used with unboxed standard frame.
does not matter -they will still interchage-both HAMILL and A.O. SMITH made those frames and that would account for the SLIGHT differences
