Distributor installed 180 out? '58 370
Will the distributor actually go into place 180 degrees out?
Thad 1958 Chieftain Safari (370,4 spd, 9 passenger) Daily Driver 1966 Bonneville Wagon (Factory 421,3x2,4spd, 9 passenger) On the road!! |
Yes, yes is the answer to that question. Just did it. Well, fixed one that was 180 out....
Or you could just move the wires a half turn counter clockwise. Chevy guys would probably move the wires a half turn clockwise instead.
My Pontiac is a '57 GMC with its original 347" Pontiac V8 and dual-range Hydra-Matic. |
Yes it will, and if the engine fires it will blow your muffler. Ask me how I know.
69 Z 302 M21 3.73 http://www.byjanmarie.com/camaro/Z28.html 69 FB 400 http://www.byjanmarie.com/firebird/69.html 69 Camaro 327 4sp. 4.10 http://www.byjanmarie.com/camaro/69camaro.html ( SOLD) 2002 Camaro LE/SLP-(sold) 1967 Nova SS-- 327, M20, 3.73, FRT Disc |
That didn't go unnoticed, Bill...
And if it still didn't start would they say that the fuel pump's not on the right side?
Maybe lots of people noticed Jack, and only you and I think it's funny.
Not only have I seen someone do that (Chevy guy working on a Pontiac) but I've also saw one put all the rods on the crank journals with the chamfer to the inside instead of the outside of the jounal. Because they started the first rod/piston assembly in the no.1hole, which puts it to the back of the journal thinking it was a Chevy. He found out fast when the bearings all heated up and wiped out. It also squeeked--just a little---. Mark L
My Gasser '63 Catalina build. Oh sorry, it's a Street freak. Either way it's a fun build. |
Been there, done that. One brand new muffler turned inside out.
