Old 07-27-2024, 11:21 AM
Jimbobeast Jimbobeast is offline
Default how to restore a Hurst T-handle?
I have an original "open 4" T-handle Hurst shifter but the black paint surrounding the letters has long since disappeared. What is the best method of getting black paint around the lettering. I would think just run paint in that area and then remove paint from the numbers. Any tips? Also, what degree gloss paint?
Old 07-27-2024, 03:02 PM
Cammer-6 Cammer-6 is offline
degrease and clean thoroughly
then use paint thinned and in an eyedropper
or a needle bottle
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 08-03-2024, 07:15 AM
Thanks for the advice but I had doubts about my ability to get the thinned paint to flow around the tiny numbers.
I degreased and cleaned the handle with a tooth brush and mineral spirits, carefully masked what I could and then sprayed it with Eastwoods Underhood Black (semi gloss 60 degree) paint. After two minutes I removed the tape and rubbed lightly over the numbers with a paper towel soaked with mineral spirits and held taughtly over a rubber block.
I think it turned out OK.
Pics to follow, I've got a computer glitch right now.
Old 08-03-2024, 07:27 AM
here are the photos:
ID:	637780   Click image for larger version
ID:	637781   Click image for larger version
ID:	637782   Click image for larger version
The Following 2 Users Say Thank You to Jimbobeast For This Useful Post:
Thread Tools
Display Modes
