Old 08-06-2015, 12:52 AM
69FIREBIRD76MM's Avatar
Default Ebay fabricated valve covers
Anybody using the ebay, Fabricated aluminum tall valve covers, they cost $109.00 they look ok, can a 10an bung be welded or bulkhead? any input will be appreciated. Thanks
Old 08-06-2015, 01:15 AM
NeighborsComplaint's Avatar
I hate to ask the obvious, but how do you add oil? DIY hole saw for a grommet and breather?
Old 08-06-2015, 01:31 AM
66bonne's Avatar
66bonne 66bonne is offline
I've got a pair and am very pleased with them. The flange is thick and sturdy for a good seal, no warping if overtightened. I did take them to my machinist to have an oil filler hole drilled along with a hole for the -10 line for the vac pump.
If I needed another set, I'd buy them again faster than a speeding Poncho.
Jim
Old 01-07-2021, 12:22 PM
sjdiesel's Avatar
sjdiesel sjdiesel is offline
Bringing this back from the dead. I am in need of some valve covers and really like the fabricated valve cover look. The butler prices are out of control IMHO. And came across these eBay covers. I know breather holes and a fill hole needs to be added but overall how are you guys lining them? Sounds like 66bonne really likes them.
For anyone else that looks in this thread, what fabricated valve covers are you running and how do you like them?
Sean
1967 GTO
Koerner built 468 with Edelbrock RP’s 315cfm by Butler, Luanti Voodoo HR 20510713, 4l80e, Holley Terminator EFI
Old 01-07-2021, 02:31 PM
firechickenman's Avatar
firechickenman firechickenman is offline
I've had a set on my Firebird since 2014. I like them a lot especially for the price. I cut a couple holes in them to add grommets and breathers. They seal really nice with a set of TIP 5/16" rubber/steel gaskets.
'68 Firebird
463/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radials/1.37 60'/6.30@108.80/9.93@135.14
Hot Rod Drag Week finishing averages:
2014 - 11.12 @ 118.56
2015 - 10.84 @ 124.97
2016 - 10.56 @ 127.88
2017 - 10.29 @ 130.74
2018 - 10.29 @ 130.53
2019 - 10.16 @ 132.34
2021 - 10.09 @ 132.69
2022 - 10.13 @ 133.07
9.93 run - https://youtu.be/hII0_UlYM4U
The Following User Says Thank You to firechickenman For This Useful Post:
Old 01-07-2021, 04:09 PM
Yes, I have a set, and love them. The set I have does scratch a little easy, but once you know, you can be careful.
Some of the expensive ones have a ceramic coating on them, and believe that may be why some cost more than others.
Old 01-07-2021, 04:59 PM
Schurkey Schurkey is online now
What would the Communist Chinese know about adding oil?
Old 01-07-2021, 05:27 PM
JLMounce JLMounce is offline
I'm glad to see people like these. I've been thinking about these, but have been afraid to pull the trigger. You can get them with holes pre-drilled now.
-Jason
1969 Pontiac Firebird
Old 01-07-2021, 10:23 PM
I can just see the instructions: "Making sure as all oil is full before install valve cover."
Of course they are universal and customizable but it is an amusing thought.
I've been eyeballing these for some time now. https://www.ebay.com/itm/Pontiac-V8-326-455-Nostalgic-Polished-Aluminum-Finned-Tall-Valve-Covers-w-Hole/143876739439?epid=14029492118&hash=item217fb8d16f: g5cAAOSwL1tfznJf
Triple Black 1971 GTO
Old 01-07-2021, 10:49 PM
flat-bill flat-bill is offline
Default valve covers
I have these on my motor. If I am doing this attachment thing correctly. Billk
Old 01-08-2021, 10:24 PM
ErikW's Avatar
ErikW ErikW is offline
Have 4 sets on 4 different cars. They work great. You can drill holes and add breathers, weld in an oil cap bung, weld in AN fittings for vacuum pump or remote breather tank. The tall ones need to be notched to clear a factory brake booster on a second gen f body. But for the price, you can't beat them
1964 GTO
9.76 @ 137mph
1966 LeMans. 462, SD prepped Kaufman D ports. 11.90 @ 112
1976 Trans Am twin turbo 462, SD Edelbrock heads 8.50@159
2009 G8 GT
Old 01-09-2021, 03:21 PM
1968GTO421's Avatar
I used NeighborsComplaint's link to check out hid valve covers...NIce. But then I saw some that had more appeal to my taste:
https://www.ebay.com/itm/Pontiac-326....c101195.m1851
Thanks Neighbor!
GTOAA--https://www.gtoaa.org/
