Ebay fabricated valve covers
Anybody using the ebay, Fabricated aluminum tall valve covers, they cost $109.00 they look ok, can a 10an bung be welded or bulkhead? any input will be appreciated. Thanks
I hate to ask the obvious, but how do you add oil? DIY hole saw for a grommet and breather?
I've got a pair and am very pleased with them. The flange is thick and sturdy for a good seal, no warping if overtightened. I did take them to my machinist to have an oil filler hole drilled along with a hole for the -10 line for the vac pump.
If I needed another set, I'd buy them again faster than a speeding Poncho. Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8. |
Bringing this back from the dead. I am in need of some valve covers and really like the fabricated valve cover look. The butler prices are out of control IMHO. And came across these eBay covers. I know breather holes and a fill hole needs to be added but overall how are you guys lining them? Sounds like 66bonne really likes them.
For anyone else that looks in this thread, what fabricated valve covers are you running and how do you like them?
Sean 1967 GTO Koerner built 468 with Edelbrock RP’s 315cfm by Butler, Luanti Voodoo HR 20510713, 4l80e, Holley Terminator EFI |
I've had a set on my Firebird since 2014. I like them a lot especially for the price. I cut a couple holes in them to add grommets and breathers. They seal really nice with a set of TIP 5/16" rubber/steel gaskets.
'68 Firebird 463/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radials/1.37 60'/6.30@108.80/9.93@135.14 Hot Rod Drag Week finishing averages: 2014 - 11.12 @ 118.56 2015 - 10.84 @ 124.97 2016 - 10.56 @ 127.88 2017 - 10.29 @ 130.74 2018 - 10.29 @ 130.53 2019 - 10.16 @ 132.34 2021 - 10.09 @ 132.69 2022 - 10.13 @ 133.07 9.93 run - https://youtu.be/hII0_UlYM4U |
The Following User Says Thank You to firechickenman For This Useful Post: | ||
Yes, I have a set, and love them. The set I have does scratch a little easy, but once you know, you can be careful.
Some of the expensive ones have a ceramic coating on them, and believe that may be why some cost more than others. .
The Following User Says Thank You to HWYSTR455 For This Useful Post: | ||
What would the Communist Chinese know about adding oil?
I'm glad to see people like these. I've been thinking about these, but have been afraid to pull the trigger. You can get them with holes pre-drilled now.
I can just see the instructions: "Making sure as all oil is full before install valve cover."
Of course they are universal and customizable but it is an amusing thought. I've been eyeballing these for some time now. https://www.ebay.com/itm/Pontiac-V8-326-455-Nostalgic-Polished-Aluminum-Finned-Tall-Valve-Covers-w-Hole/143876739439?epid=14029492118&hash=item217fb8d16f: g5cAAOSwL1tfznJf
Triple Black 1971 GTO |
The Following User Says Thank You to NeighborsComplaint For This Useful Post: | ||
valve covers
I have these on my motor. If I am doing this attachment thing correctly. Billk
Have 4 sets on 4 different cars. They work great. You can drill holes and add breathers, weld in an oil cap bung, weld in AN fittings for vacuum pump or remote breather tank. The tall ones need to be notched to clear a factory brake booster on a second gen f body. But for the price, you can't beat them
1964 GTO 501, Edelbrock Heads NA, 3460 lbs. 9.76 @ 137mph 1971 Trans Am Lucy Blue, 11.56 @ 115 1966 LeMans. 462, SD prepped Kaufman D ports. 11.90 @ 112 1976 Trans Am twin turbo 462, SD Edelbrock heads 8.50@159 2009 G8 GT |
https://www.ebay.com/itm/Pontiac-326....c101195.m1851 Thanks Neighbor!
"No replacement for displacement!" GTOAA--https://www.gtoaa.org/ |
