Old 12-31-2020, 12:37 AM
slowbird's Avatar
slowbird slowbird is offline
Short block is basically together (the hard stuff anyway) still watching on heads getting milled. Official cam specs are 243-249 .638-.600 111ls installed at 109. Looking forward to seeing how the tri-power does vs the RPM intake vs T2.
  #42
Old 12-31-2020, 10:58 AM
tom s tom s is offline
too bad no bathtub to throw on it for grins!Tom
  #43
Old 12-31-2020, 12:35 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Actually we might be able to do that.... Good idea, I'll see if I can make that happen. I sure hope Slowbird is efficient in changing manifolds.
If not I'm dyno'ing a pretty stout pump gas engine soon using a Wenzler tunnel ram, I should be able to do a back to back and see how close the Bathtub comes.
Go fast, see Elvis!
  #44
Old 12-31-2020, 01:08 PM
slowbird's Avatar
Im totally game! I can swap intakes pretty fast
  #45
Old 12-31-2020, 01:28 PM
Steve C. Steve C. is offline
Make sure all these intakes are port matched to the cylinder heads. MANY years ago Tom offered to loan me a real Bathtub intake to dyno test with my 4.125 stroke 450 engine. It would of been fun but my intake ports would of been too big, that and I'd have to round up the two carbs.. The engine ended up making 680 hp at 6900/7000 rpm with a Victor intake and old Brad Urban Stage III 750 double pumper Holley.
Old information here:
  #46
Old 12-31-2020, 01:38 PM
PAUL K's Avatar
Good point Steve fortunately both engines are using the same port window and as luck would have it the Bathtub manifold will be fitted to a third engine that has the same size port window.
Go fast, see Elvis!
  #47
Old 12-31-2020, 01:42 PM
Actually Jim Robertson is converting mine right now,not sure on that one what I will have him make the port exit yet as it is going on a stock set of 96 heads.I with I knew for sure if a RA IV port would seal on the head I would have him make them IV size.For street driving im sure it would not make any diff of the miss match.Tom
  #48
Old 12-31-2020, 01:50 PM
Xover pic
ID:	557249   Click image for larger version
  #49
Old 03-03-2021, 08:57 PM
slowbird's Avatar
Heads are finished, now i just need to find time to finish the assembly. Sadly time has been pretty short lately.
  #50
Old 03-03-2021, 09:03 PM
Mike Davis's Avatar
Who did the casting numbers on the heads??
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
  #51
Old 03-03-2021, 09:04 PM
vertigto's Avatar
vertigto vertigto is offline
  #52
Old 03-03-2021, 09:07 PM
slowbird's Avatar
Paul K did the heads. Turned out pretty good in opinion.
  #53
Old 03-03-2021, 09:55 PM
blueghoast's Avatar
Originally Posted by ta man View Post
Thanks Steve. 600 hp and close to 20mpg is achievable with pump gas..with a mild 235/236 duration...try saying that 20 years or even 10 years ago.
I would like to see a dyno sheet on that one, I don't think it's possible
with that small a cam. I just dynoed one of my motors and it was hard
to get over 600 hp. Mine made 625.6 hp and 634 lbs I was hoping for more.
I'll get a dyno sheet up here soon.
GT.
  #54
Old 03-03-2021, 09:56 PM
blueghoast's Avatar
Oh Yea 550HP 589trq
GT
  #55
Old 03-03-2021, 09:57 PM
slowbird's Avatar
GT.
Ya please share more details.
  #56
Old 03-03-2021, 11:49 PM
blueghoast's Avatar
Default 462 Dyno
Yea sorry.
462 Factory crank eagle rods ross pistons moly-file fit rings E-Heads
with 320 cfm 2.190 it-1.770 ext valves 72cc chambers cnc chambers
11:98:1 comp victor with 1050 dom and 1-inch spacer
Cam is .626 lift 1.5 rocker dur @50 274-278 with a 106 LSA.
I could'nt beleive it made most power at 37 deg timing with the
newer chamber but it did.
GT.
  #57
Old 03-03-2021, 11:57 PM
slowbird's Avatar
Yea sorry.
GT.
Very interesting, what were the hp/tq rpm peaks?
  #58
Old 03-04-2021, 12:13 AM
pastry_chef's Avatar
I would like to see a dyno sheet on that one, I don't think it's possible with that small a cam
I haven't seen it with a Pontiac but I have many examples that clear 600 HP with 46x cubes and similar hydraulic rollers.
This uses an Isky 238 / 248 with .578 / .608 - 109 LSA.
https://www.youtube.com/watch?v=rIIoazbO0d0
Hits 600 HP @ 5400 RPM and continues to climb.
Induction flowing 300 ish isn't going to do it.
  #59
Old 03-04-2021, 12:19 AM
blueghoast's Avatar
HP=5900-6000
FT=4400-4500
GT
  #60
Old 03-04-2021, 09:24 AM
slowbird's Avatar
HP=5900-6000
FT=4400-4500
GT
Who ported the heads?
