Old 03-24-2023, 09:01 AM
mgarblik mgarblik is offline
Default 62 Catalina Sway Bars
I think it's a safe bet a 62 Catalina won't be winning any road races in the near future. However, with my car now running a proper power level engine, cornering like a beached whale is a little scary at times. I have read many threads in this forum about rear sway bars for these cars. I think I have settled on a 1" bar for the rear that attaches to the lower control arms and is out of the way of exhaust and shocks. Just have to box the lower arms. That leaves the spaghetti sized 7/8" front sway bar. I haven't found ANY alternative bars for the front at all. Also no discussion of this topic. Is anyone doing anything up front on these cars? Seems a 7/8" bar on the front and 1" bar on the rear would not give the best balance. The rear steering geometry would dictate a smaller bar would be OK, but a 7/8" bar on a 4000 lb. plus car seems extra tiny. Comments, suggestions, part numbers? Thanks
Old 03-24-2023, 09:43 AM
tom s tom s is offline
I put one on my 62,think I got it from Fabcraft or RARE?Tom
Old 03-24-2023, 09:46 AM
Stuart's Avatar
Stuart Stuart is offline
I assume you're talking about the front and rear bars from Addco...they're the only game in town I'm aware of, as far as ready made parts go. It does seem odd the only ones they offer are a 1" rear and .875" front.
edit: Like Tom says, Fabcraft does have a rear sway bar that's 3/4". However, I think it mounts differently than the Addco bar, so the mechanical advantage may be different.
Old 03-24-2023, 09:55 AM
imposter's Avatar
imposter imposter is offline
Qa1
has a set of tubular lowers with the bar that bolts to it nice piece
Old 03-24-2023, 10:25 AM
I will check into the Qa1 bar. I don't want to change control arms, but want to see what they have. I was actually leaning toward a rear bar from UMI mentioned in another thread and stocked at Summit. Looks just like the Addco bar for the rear. The front was my primary concern in this thread. 7/8" just looks tiny on this giant car. Seems like a 1 1/8"-1 1/4" would be more appropriate but it needs to mount in stock location.
Old 03-24-2023, 10:51 AM
61-63's Avatar
61-63 61-63 is offline
I have a Fabcraft rear bar I installed on my '63 Catalina. I've removed it and will sell it. The vertical rods went missing but could be replaced with threaded rod.
ID:	609582   Click image for larger version
The Following User Says Thank You to 61-63 For This Useful Post:
Old 03-24-2023, 11:57 AM
I appreciate the offer very much. If I can find one that fits for sure, I really like the way the bars fit on the lower control arms. I know that's not proper for these cars as far as factory installation. But attaching to the control arms eliminates all the fitment issues of being really close to the shocks and the exhaust system. I have a complete 2 1/2'" exhaust system and it is all welded. So I don't want to mess with sway bar interference. Still thinking about it. Thanks again. Have you ever done anything with a front bar, other than the tiny 7/8" stock one?
Old 03-24-2023, 12:00 PM
61-63's Avatar
No never messed with the front bar.
Old 03-24-2023, 12:47 PM
misterp266's Avatar
If Mike passes on your bar, I’m interested, LMK. Thanks
Mike, I installed the Addco bar on the front of my ‘63 and it fits very tightly inside the crossmember. Not sure a bigger bar would fit. I put one on my ‘66, (1 1/8”) with no rear bar and it made a huge difference just with normal cornering and off-ramps. Unless you plan to race Eric’s T/A around the track, I think you’ll be happy.
" Darksiders Rule "
Old 03-24-2023, 01:59 PM
I forgot the front bar fits within the front crossmember. Haven't had my car on the rack in 6 months. So to clarify, you replaced the stock PMD front 7/8" sway bar with an Addco 7/8" sway bar and it made a noticeable improvement? Better material and more initial twist in the bar I guess? Do I have that correct? The Addco bar is pretty expensive and I don't want to buy one if it' s not going to do anything. My OE bar is not broken or anything. It has new bushings and ends.
Old 03-24-2023, 02:37 PM
misterp266's Avatar
My factory 1963 front bar is 13/16”. The Addco 199 bar that I replaced it with is 1 1/8”. I just measured both to confirm. I have not driven the ‘63 as it’s still being built. I was commenting on my 1966 Catalina that I put an Addco 857 bar that is also 1 1/8”. That made a big difference even without adding a rear bar although I’m sure that would be better.
I did see the 199 bar described as 7/8” in a few ads but unless they’ve changed it, that’s incorrect. Mine is 1 1/8” and fits very tight.
Hope that helps you!
Here’s a link…..https://www.sfxperformance.com/parts/ADD199.htm
" Darksiders Rule "
Old 03-24-2023, 02:52 PM
...If I can find one that fits for sure, I really like the way the bars fit on the lower control arms...
The bar that bolts up solidly to the lower control arms will bind up the suspension. The one 61-63 is offering is a good solution if it clears.
Old 03-24-2023, 06:42 PM
That is great information. I can see a 1 1/8" bar being a huge improvement over a 13/16" bar or 7/8" bar. Absolutely. If it fit a 63 it should fit a 62. These parts seem to all be listed to fit 61-64. As for the rear, I can see possible binding with the lower arm mounted bar. But why would it bind on car and work fine on so many other models? Possibly the greater travel on the rear suspension of the 61-64 cars?
Old 03-24-2023, 07:20 PM
real61ss's Avatar
real61ss real61ss is offline
I have a couple of the Fabcraft bars, they mount like the factory bars mounted, struts are behind the rear wheels
Tommy's Early Muscle Cars
1959 Pontiac Catalina Sport Coupe 3x2 3 speed manual
1960 Pontiac Ventura 425A / 4 speed
1961 Pontiac Catalina Tri Power / 4 speed
1961 Ford Starliner 390 / 401/ 4 speed
1962 Corvette 327/300 / 4 speed
1962 Gran Prix Tri Power / 4 speed
1963 Pontiac Catalina 421/ 4 speed
1964 Pontiac Catalina 3x2 / 4 speed
The Following User Says Thank You to real61ss For This Useful Post:
Old 03-24-2023, 08:48 PM
imposter's Avatar
i bought a anti roll bar from spohn nice piece as well and agree about the control arm mounted piece not good
Old 03-24-2023, 08:52 PM
Stuart's Avatar
Originally Posted by imposter View Post
Qa1 has a set of tubular lowers with the bar that bolts to it nice piece
Can you put up a link? I looked at the QA1 website and wasn't able to find anything for a full size Pontiac older than 1978.
Old 03-24-2023, 09:00 PM
imposter's Avatar
here's your ticket
https://fabcraftmetalworks.com/produ...sisch8-0520-2/
https://pmtfabrication.com/product/1...-rear-sway-bar
https://pmtfabrication.com/product/1...front-sway-bar
Old 03-25-2023, 09:25 AM
pfilean's Avatar
pfilean pfilean is offline
Have been tempted several times to buy the Fabcraft stabilizer. Just afraid to have to drop the tank and maybe exhaust to get access to drill holes. As near as I can tell the frame does not already have the proper holes. The idea of removing other pieces and then laying on my back with a half inch Milwaukee drill is not appealing.
As to the question of interference with shocks and exhaust (especially oversize) not that the 61 manual for Safari shows the stabilizer link mounted outboard the frame not inboard like the Fabcraft. Not sure what the police optional bar shows. Of course, the Safari had side exit exhaust not rear exit and the picture does look very tight.
Old 03-25-2023, 01:05 PM
misterp266's Avatar
Is a ‘61 frame narrower in the rear? That’s the first pic I’ve seen of one mounted outside the frame. Would be easier to mount the brackets though.
Looks mighty close to the exhaust. I would want to install the bar before the exhaust for sure.
Turned the pic.
" Darksiders Rule "
Old 03-25-2023, 03:12 PM
Stuart's Avatar
They have different part numbers, but I'm pretty sure 1961 and 1962 frames are essentially identical - there may be detail differences.
