My 66 ready to go!
The Following 4 Users Say Thank You to Jromaine87 For This Useful Post: | ||
Very Nice!!!!!!!!!!!!!!!!!!!!!!!!
Tom V.
Bad Azz!!!
That's a very nice piece sir
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow. |
Slick Machine!
Carburetor building & modification services Servicing the Pontiac community over 25 years |
Very nice
2008KRE Q16 Winner 2014 atco raceway doorslammer winner 86 grand am tube car 8.95 @152 455 eheads solid flat tappet cam Hoffman Racing building and racing Pontiacs for 35 years |
That is a nice piece of Pontiac. Can you tell us more about the car ? 4 link, what kind of rear and gears ect.
How much does it weigh. Its going to lay down some good numbers for sure. looks fast just sitting there. |
Thanks for the crank. Sent from my iPhone using Tapatalk |
Now that's real nice !!
It’s a 1966 GTO Tube chassis Weighs 2800 with me in it with aluminum block 535 made 887 at 7000 RPM( 905) with correct vaccum 4.56 rear gears and a TH400 with 2.48,first 60 ft is 1.28ish Should do 8.70 in good air. Car used to be owned by my uncle known on PY as greaserdegreaser Sent from my iPhone using Tapatalk |
The Following User Says Thank You to Jromaine87 For This Useful Post: | ||
Beautiful car and really cool it was your Uncle's
Chris D 69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60' |
The Following User Says Thank You to OCMDGTO For This Useful Post: | ||
I love the look and finish on your car! Just curious on what tire size you have on it. With a 4:56 gear you may be turning A LOT of rpm's at the big end especially if you think it's going to run 8.70's. That would be in the 155ish MPH range.
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
The Following User Says Thank You to Gary H For This Useful Post: | ||
32 inch tall tire. I was spinning around 7400 threw the traps at 145ish before. Sent from my iPhone using Tapatalk |
You might want to think about 4.33 or 4.11 gears
The Following User Says Thank You to slowbird For This Useful Post: | ||
Very nice
Blown 4cyl's to the front |
I run a 33" tall tire and 4:33 gears. At 154 MPH I'm at around 7700 RPM's. Partially depends on how tight your convertor is. I don't think a little less gear will hurt you as light as your car is.
I ran a 9.27 at 147 this weekend, only got to make one pass as I found something in my oil filter I didn’t like, it turned out to be just debris from when I had my valley pan and oil filter resealed after the dyno session. I definitely need some work on the chassis, with a lot more torque and Hp this go round I was bouncing off the line, just wasn’t a pretty launch. Sent from my iPhone using Tapatalk |
Nice job! When is your race with the Firebird guy?
[QUOTE=Jromaine87;6406479]I ran a 9.27 at 147 this weekend, only got to make one pass as I found something in my oil filter I didn’t like, it turned out to be just debris from when I had my valley pan and oil filter resealed after the dyno session.
I definitely need some work on the chassis, with a lot more torque and Hp this go round I was bouncing off the line, just wasn’t a pretty launch. [IMG]https://uploads.tapatalk-cdn.com/20230207/8148a4677a396ca68f647d483c24fd57.jpg[/ i would put 4.11 in that thing,thats a high starting line ratio |
[QUOTE=lakefect;6406518]
