Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 01-05-2020, 02:24 PM
AIR RAM AIR RAM is offline
Default Keith Black KB Performance Pistons KB371-030+.040 455
I have a set of NEW Keith Black KB Performance Pistons KB371-030 +.040 that I had purchased for my 455 build approximately 8 years ago. They where new when purchased however, during that time I had sent them off to be ceramic coated and they have been sitting ever since. Now that I am ready to build the engine, my plans have changed for the build and have decided to add boost and stroke... so these pistons will not work.
The pics show one piston. The oil marks are just from lubing the wrist pins.
I would like $399.00 for the set SHIPPED. They are $468.00 new and that's without the coatings. Sale includes Pistons, Pins and locks. You will still Need Rings.
Here are the KB details of these pistons:
Bore (in): 4.180 in.
Bore (mm): 106.172mm
Stroke: 4.210 in.
Piston Style: Dish, with no valve reliefs
Piston Material: Hypereutectic aluminum
Compression Height (in): 1.500 in.
Piston Head Volume (cc): +30.50cc
Wrist Pin Style: Press-fit or floating
Pin Lock Rings Included: Yes
Wrist Pin Included: Yes
Pin Diameter (in): 0.981 in.
Piston Ring Thickness: 5/64 in. x 1/16 in. x 3/16 in.
Piston Rings Included: No
File Fit: No
Gapless: No
Quantity: Sold as a set of 8.
Notes: Step dish design.
Calculator Compression Calculator
Tool Stroker Combinations
Keith Black hypereutectic pistons are made from 390 aluminum alloy and heat-treated to T6 standards, which makes them 30 percent stronger than ordinary untreated hypereutectics. Their 100 percent CNC-machined crowns, high upper compression-ring location, gas-accumulator groove, drilled oil returns, and spiral-lock retainer grooves make these pistons outstanding for performance applications. They have a lightweight, rigid-rib skirt design that stabilizes the piston in the bore. All of this adds up to pistons that fit tighter than forged types, provide improved oil control, reduce blowby, increase ring life, eliminate cold start-up knocking, and won't cost you an arm and a leg! Thousands of models are available—find the set and options designed for your vehicle and engine application.
I accept Pay Pal and can accept most major credit cards.
If you have any questions or concerns please feel free to contact me.
SPEED SAFE, NICK
ID:	528226   Click image for larger version
ID:	528227   Click image for larger version
ID:	528228   Click image for larger version
"The grass is not greener on the other side, its just fertilized with different $h!t"
Old 01-05-2020, 06:02 PM
The pistons + Pins + retainers combined weigh 657 Grams.
SPEED SAFE, NICK
Old 01-09-2020, 09:07 PM
Bump
SPEED SAFE, NICK
Old 01-12-2020, 10:35 PM
Price dropped to 350.00 shipped.
https://www.airram.com/product.php?c...hquery=pistons
SPEED SAFE, NICK
Old 01-18-2020, 10:59 AM
Still available, $350.00 + Ride
Click here for a direct link to purchase using Pay Pal or credit card.
SPEED SAFE, NICK
Old 02-01-2020, 10:33 PM
maxpowerta maxpowerta is offline
Do you still have these?
Old 02-07-2020, 02:31 PM
SPEED SAFE, NICK
Old 02-15-2020, 02:15 PM
** SOLD **
Thanks for looking!
SPEED SAFE, NICK
