Old 01-20-2020, 10:28 PM
WARCHIEF400 WARCHIEF400 is offline
Default 1968-69 GTO/LEMANS PARTS
1968 Hurst Dual Gate Shifter Restored with shifter cable and wiring harness $525.00
1968 Carb Restored $900.00
1968 Rear bumper brackets $75.00
1968 GTO Passenger door Glass with lower frame and bracket $100.00
1968-69 Lemans front bumper brackets $75.00
1968 Lemans front bumper black plastic insert $25.00
1968 Lemans front bumper grill brackets $25.00
1968-69 power brake booster $50.00
1968-72 GTO/Lemans lower main duct and vents $125.00
1968-72 Intermediate steering shafts $50.00
1968-72 Rear Windshields $80.00
1968-72 Coils $25.00
1964-79 Oil Filter housings $85.00 each
1968-72 front lower window reveal molding $60.00
1968-72 rear front upper fender chrome moldings $30.00 pr.
1968-71 Throttle cable $45.00
1965-78 Turbo 400 Transmission oil pans $50.00
1968-72 NOS FRONT WINDSHIELD UPPER STAINLESS MOLDING $175.00
1968-72 NOS PASSENGER SIDE FRONT WINDSHIELD STAINLESS MOLDING $90.00
1968-72 door vents pr. $20.00
1968-72 positive battery to starter heat shield tube,
1968-72 1/4 window glass chrome trim moldings $30.00 pr.
1968-72 window regulators set of 4 $150.00
1968-72 brake pedal assembly $75.00
1968-72 emergency brake pedal and bracket $50.00
1968-72 rear license plate bracket and holder $35.00,
1968-72 front armrest bases parchment, black $25.00pr,
1968-72 door & 1/4 glass regulators $50.00
1968-72 water thermostat housings $20.00 ,
1968-72 door hinges $50.00
1968-72 points distributors $80.00
1968-72 wiper transmission assembly (2) $75.00
1968-72 blower motors $25.00
1968-72 a/c inner boxes $150.00,
1968-72 headliner bows $50.00 set
1969 GTO CARB still in DELCO BOX $850.00
1969 Water pump Date Code is Jan of 69 $50.00 with divider plate
1969-72 AM &FM RADIO PULLED OUT IN 1983 WORKS $475.00
1969-72 AM RADIO WORKS $200.00
1969-75 Harmonic balancer $50.00
11 Bolt Timing Cover $110.00
11 Bolt Timing Cover withy divider plate and pump $150.00
Full length windage trays 80.00
1968-72 Show Quality Front Window Stainless Moldings, Professionally Polished $300.00
NOS A/C Delco PVC $9.00,
NOS PULLEY 481040 still in GM BOX $100.00
NOS A/C Delco oil Filters PF 24 $11.00 each
1969-72 Goldenrod/Tan steering wheel crack free $125.00
1969-72 auto shifters $130.00
Fuel escentrics $35.00
1969-72 harmonic balancer off low mileage car $50.00,
flexplates $35.00
1969-72 Standard Gauge & Speedometer cluster $65.00
1968-72 radio rear support bracket $25.00
1968-72 Tag light & bracket $15.00
Distributors 1148 Feb13,70, 1253 Jun 26,68, 2007 Nov 28,69, 2189 Apr 24,72, 2513 Nov 15,73 all distributors $80.00
used pulleys 481040XT water pump pulley, 481038YB crank pulley, 480507 crank pulley, 8inch 2 grove water pump pulley,
480509
TCS Switch $75.00
NON A/C HEATER HOSE BRACKET $25.00
Pontiac oil pan $85.00
new points and condensers __________________
Timmy Mallory Email me at temallory@msn.com
Timmy Mallory
Old 06-24-2020, 05:37 PM
68 carb 7028270 has been sold thanks Gary!
Timmy Mallory
