Old 12-29-2019, 11:02 PM
Firebob's Avatar
Firebob Firebob is offline
Default Pitman arm
It was suggested that I should post here.
I pulled the steering out from the 67 and bought all new except for the pitman arm. I removed it and it has a crimped in stud ball joint that apparently is not designed to b replaced by the consumer. Luckily they are available from the vendors. Although most appear to be the straight version and not the the power steering curved version. I think Ames shows the curved one n their catalog but says not to be used with variable ratio boxes( not sure what difference that makes). The 69 type pitman arm has the joint in the center link instead and I've heard that the center link that's sold is a smaller diameter piece that was made for the Camaro or the 6 cylinder model. I've heard that the curved 9 arm is very tough to come by.
Robert
69 Firebird-462/Edel round ports/currently running the Holley Sniper/4sp/3.23posi/Deluxe Int/pwr st/vintage air/4wl disc( a work in progress-always )
http://youtu.be/eaWBd3M9MN4
Old 12-30-2019, 05:26 PM
RAJ7395's Avatar
RAJ7395 RAJ7395 is offline
Check e-bay as I saw one for sale on there last week.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int
1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int
1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int
