Old 01-10-2020, 09:30 AM
slowbird's Avatar
slowbird slowbird is offline
Originally Posted by grandville455 View Post
Interesting that the Exh with a pipe was a tad less or the same til the very end and even then just barely more.I always thought a pipe would add more flow when testing them or is that just with a ****ty port lol
I think that's 2 different exhaust ports tested with pipe, just like there appears to be two different intake ports tested?
Old 01-14-2020, 08:03 PM
cgeise's Avatar
cgeise cgeise is offline
Just FYI I would not run a 1250 on that motor if your running a throttle stop class
Old 01-15-2020, 10:56 AM
jimmy daniel's Avatar
jimmy daniel jimmy daniel is offline
Not much choice now. I’ve already bought it and put it on. I’ll see how it works in a couple weeks in Orlando.
1965 TriPower GTO, 1967 GTO, 1969 GTO, 1969 Judge, 1972 GTO, 1977 Smokey and the Bandit, 1989 TA ProStreet, 1968 Firebird NHRA 10.90 racecar, 1963 Tempest S/Gas
Old 01-16-2020, 01:35 PM
cgeise's Avatar
let us know
Old 01-16-2020, 02:16 PM
PAUL K's Avatar
PAUL K PAUL K is online now
Mind elaborating on this? Just curious
Go fast, see Elvis!
Old 01-16-2020, 09:41 PM
Now I’m curious as well. Came off a Div 3 S/C winner car. But it won’t take but one good day of testing and I’ll know. I’ll get back and let everybody know how it did.
Old 01-17-2020, 04:15 PM
cgeise's Avatar
The larger carb on a smaller engine looses signal when it goes on the throttle stop more so than a smaller carb -- causing an inconsistent drop to dead stall -- It can be helped by raising the dead stall but then you end up with way more timer in the box than is ness. also in a lot of cases it will not pull off the stop as well as a 1050. there some variable with an under carb stop vs a linkage stop but that's the story in a nut shell.
The Following User Says Thank You to cgeise For This Useful Post:
Old 01-17-2020, 04:17 PM
cgeise's Avatar
The super comp car made it work do to a much higher dead stall is my guess and most have larger engines --- and I suspect a very good driver --
Old 01-19-2020, 01:22 AM
Loosened the converter up to around 67-6800 stall. I’ll know after after first race. May have to go back to the 1050?? The Maxspeed has worked well for me in several applications but I guess I’ll know soon enough,
Old 01-24-2020, 09:47 PM
S/st 54's Avatar
S/st 54 S/st 54 is offline
Jimmy, what was your 60’ times last year? I’m sure I have asked before but like a lot of us I forgot lol.
What was your stop rpm/Cruz rpm last year with the 1050,and do you plan on changing it with the 1250?
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz
“It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life”
Notre Dame Head Coach Marcus Freeman
69 GTO NHRA Super Street Car
2860lbs 10.890@157.08 MPH in Iowa in June’23 ,157.56 MPH in Gainesville in March ‘23
Old 01-25-2020, 12:49 AM
My 60s were low 1.80s. I want to be slower than that. My cruise rpm was steady at 4000. I’m going to change from on at .05 and shift at .15 to .05 on and shift at .05 per APD. That should slow the 60 ft some.
Old 01-25-2020, 12:52 AM
Getting close
ID:	529919   Click image for larger version
ID:	529920   Click image for larger version
Old 01-25-2020, 12:53 AM
More
Old 01-25-2020, 08:32 PM
S/st 54's Avatar
Thank you for the info.
It’s Looking good Jimmy! Good Luck next weekend!!
Old 02-01-2020, 04:48 PM
S/st 54's Avatar
Updates?
I hear Mother Nature got her way today so no racing till Tomorrow.
But you had to have gotten 3 time trials,I couldn’t find any info on the live timing. Any updates?
Old 02-01-2020, 10:04 PM
Updates?
Didn’t get it finished until today so I missed Orlando. I’ll do South Ga, Belle Rose and Gainesville all back to back. I’m testing here at home tomorrow. Well see how it goes
Old 02-03-2020, 01:38 PM
Ken MacNicol's Avatar
Ken MacNicol Ken MacNicol is offline
Well , how did it go ?
  #38
Old 02-03-2020, 04:22 PM
Testing went well. I think I can make a few adjustments and I should be close. Throttle stop laid flat. Just have to figure out ratios
  #39
Old 03-12-2020, 11:40 PM
Well results are back and I hate to say I saw no improvement. Ran Gainesville and I was still 10.90 @ 151. Same exact speed as last year. Car ran well and was very consistent and predictable but didn’t pick up anywhere. I jetted up and down and had time to try the timing at 32 and 34. I’m at a loss here.?
  #40
Old 03-13-2020, 12:14 AM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
So let me start by saying that i have no experience with throttle stop racing. But without running it hard where would you pick up? Were you looking to add more time on the stop and run the same? Asking so i can understand, no to be sarcastic.
