Old 01-12-2020, 01:52 PM
61vette 61vette is offline
Default 1965 Front wheel hubs needed.
Hi everyone, I'm in need of two original front wheel hubs for my 1965 GTO. My original ones had the bearing races spin in the hub and worn out hub to where I can't install new bearing races without the races turning. If anyone has a set let me know. Thanks, Larry
Old 01-13-2020, 06:01 AM
trynsave trynsave is offline
pm sent
Old 01-14-2020, 06:35 AM
Default 65 hubs
did u get my message?
Old 01-24-2020, 11:03 PM
Scott Thelander's Avatar
did try n save get you taken care of ??
matching pair with fresh bath ...
lug threads are great,,, they cleaned up nice AFTER the pictures
tight races ... just pulled from a 66 chevelle elcamino
along with all 4 original delco merraine wheel cylinders..a week ago
goin back for the 12 bolt posi housing next dry day,,,
Scott
ID:	529916   Click image for larger version
ID:	529917   Click image for larger version
Old 01-25-2020, 05:58 AM
scott-im still waiting on an ansewer from him
Old 01-25-2020, 12:24 PM
Scott, can you PM me. I'm interested in your hubs. Thanks
Old 11-26-2022, 03:09 PM
tallrandyb's Avatar
tallrandyb tallrandyb is offline
Anybody else have 65 GTO hubs? Is there something I'm missing where these parts aren't sold by Ames and don't seem to be available anywhere?
I've got old hubs and smooth exterior drums, but one of them is not mating flat on the passenger front: it appears the face of the hub is not flat so once you tap in a couple of lugs they sit flat, then when you go to tap down some on the other side then the hub pops back up from the drum on the other side.
With the .500" splined sections of the lug studs, there is just a very thin part left to "bite" into the drum.
I'm up for buying new drums and hubs and putting new bearing races/seals in etc, but I am not seeing hubs out there.
thanks!
Old 11-26-2022, 10:46 PM
can you post a couple pictures of yours
the back side too
castings change ....
Scott
I may have a single that DOES NOT have the same back side casting as in the picture
and I know where another is that I stashed a few months ago in a local wrecking yard,,,,,
Old 11-27-2022, 08:15 AM
tallrandyb's Avatar
Check my public album, I posted four pix of the front and rear of the hub, thanks!
Old 11-30-2022, 08:46 AM
tallrandyb's Avatar
Were you able to see my public album? If not, I’ll post the pix here. Thanks!
Old 12-01-2022, 08:23 AM
Andre's Avatar
Andre Andre is offline
The lug holes in the drums need to be enlarged slightly because the original drum and hub were not supposed to be serviced separately. That changed in 1968, the drum and hub are serviced separately. The new drums that are available are intended to be used with the 68 and later hub, but you can use them with the older style hub with the minor modification I mentioned above.
Old 12-02-2022, 08:09 AM
tallrandyb's Avatar
Thanks Andre. I need to replace at least one hub, the drums are fine. Just looking for a correct solution since the face of the hub appears to not be flat.
