#221
I think Dave's wide port Edelbrock is better. Thanks
Blown 4cyl's to the front |
#223
All good questions
#224
Interesting, thanks for sharing
#225
Knowing Dil, I can see where a hemi fits well with his "Gasser Gang" image.
#226
At any rate 40 or 60 horsepower jump in a 4 banger is quite a jump. If it was done on a big V8 even ore power. I would say Dave Wilcox knows what he is doing. I asked him if he could get 400+cfm out of High Ports with std pushrod and 2.20 valve and he just said "yes". I might give him a crack at it. Its like high end E wide port performance but no offset stuff or huge valves. Stud girdle and go. |
#227
A 400cfm standard pushrod HP head is nothing like a 400cfm wide port e-head. |
#228
The Wilcox ram air 5 heads I have coolant runs through. 2 separate passages on each head on intake and exhaust sides front to rear.
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow. |
#229
Hasn't Dan Barton gotten 400+ cfm out of a KRE HP with standard push rod location? Stan
#230
Real close to it
#231
If you are looking for all out performance a 400cfm wide-port will make better average power than a 400cfm standard pushrod location head more times than not.... A LOT more to it than "CFM"!
#232
I'll take a 370cfm wide port e-head (if done right) vs a 400cfm standard pushrod hp head
#233
Would you be willing to share what kind of CSA each head has? Stan
#234
No....but it's not only the cross section size but where the smallest area is placed. It usually ends up at the pushrod pinch point, head bolt bulge or valve seat area.
#235
Just a guess but i'd bet the difference is .3-.4 sq inches
#236
I don't think the std HP head would make as much power on a equal footing. It is a smaller valve and smaller choke point. But does it matter ? |
#237
Some pics of Dil's Hemi Head!
GTO George |
#238
Cool George. Are there any with al the rockers on ?
The holes for the spark plugs do not go down the center of the valve cover. Are they close to the middle of the chamber ? Any chamber pics ? Thanks. This stuff has to start out somewhere. I think a engine like this is a good start vs trying to make huge power right off the bat. |
#239
I would like to see a picture of the combustion chamber also.
Stan
#240
GTO George |
Thread Tools | |
Display Modes | |
