Old 01-02-2024, 12:36 PM
arbys's Avatar
arbys arbys is offline
Default 66 Lemans 4 speed transmission crossmember
Any ideas on how this transmission crossmember is positioned, top, bottom, drivers or passenger side?
ID:	625848   Click image for larger version
ID:	625849   Click image for larger version
Old 01-02-2024, 01:17 PM
65gto69's Avatar
65gto69 65gto69 is offline
In your second picture, what you are looking at is the top of the cross member the part that is closest to the floor board when mounted. It is also positioned correctly in this photo if you were the engine.
Mark
1965 GTO: 467 (Built By Dan Willever), 400 Block, Eagle 4.25 Stroke, Eagle 6.8 Rods, BRC Pistons, Custom Grind Hydraulic Roller Cam, Edelbrock 72cc Heads Ported, HS Rockers, Doug's Headers, Edelbrock Victor 4150, QTF 850 Carb, TCI Flex plate, AutoGear M22 4 Speed, SPEC Clutch and Pressure Plate, 12 Bolt 3:73 Posi.
Old 01-02-2024, 01:27 PM
arbys's Avatar
Mark
Ok, I have that, which is the drivers and which is the passenger side?
Old 01-02-2024, 01:39 PM
That big half circular depression stamped into the crossmember is there to clear the passenger side vacuum modulator on automatic transmission applications, it faces forward.
The crossmember fits both automatic and manual transmission applications.
Old 01-02-2024, 01:59 PM
arbys's Avatar
Thank you.
Old 01-02-2024, 04:28 PM
arbys's Avatar
With help here and online I have it re-installed. Not that bad for a 77 YO working by myself. Thanks for the pictures and comments.
Old 01-02-2024, 05:46 PM
gtospieg gtospieg is offline
Just to add some info...the hole you see(passenger side when installed) is for the e-brake rod/hanger.
Old 01-02-2024, 06:37 PM
Cammer-6 Cammer-6 is offline
Yours has the tongue ends that a rubber isolator slips over?
IIRC it changed around then from tongue to bolted.
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 01-02-2024, 07:18 PM
arbys's Avatar
Mine has a tongue that the insulator slips over and the a clamp mounts it to the frame with a bracket.
Old 01-04-2024, 03:25 PM
I dont remember if this was a running change or a model year change to a bolted attachment.
Old 01-05-2024, 12:17 AM
GtoFM's Avatar
GtoFM GtoFM is offline
I think Pontiac used the insulators and clam shell mounts into the 70s. My 64 A-body frame has an extra set of holes that fits a bolted on crossmember like Cheby used. Maybe they shared frame parts, among other things?
Old 01-05-2024, 10:41 AM
Ive never had any 67s that used the tongue/isolators
only bolted connection
Old 01-05-2024, 11:11 AM
Cammer 6 Interesting...all of my 67's and 1 66 that I had used the insulators and clamshell attachment to frame.
Old 01-05-2024, 11:58 AM
That is strange, all of my 66 and 67 A-Bodies had the tongue/isolators, It is one of the 1st things I would do was swap out the crossmember with one I got from a Olds 442. I wonder if it was an assembly plant difference. All of my cars were local Pontiac built cars.
