transmission oil seal
Has anyone here ever replaced the front oil seal on the Hydramatic while in the car. Or is this one where it is better to pull the engine and transmission and separate and change it? Don't have a car lift.
Even without knowing WHAT is leaking, engine and Hydro must be separated (pull engine or trans or both). R & R of an early HydraMatic is quite nasty- usually better off pulling engine/trans as a unit.
Last summer (for reasons I won't try to explain here) I pulled the HydroStick out the bottom of my GMC to repair it- nasty, nasty. I did come up with one improvement to the process (posted a picture somewhere in this forum)- I machined the flywheel for a square-section O-ring in place of the paper gasket, which made re-installing the hydro MUCH smoother.
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) Last edited by Jack Gifford; 04-30-2020 at 03:05 PM. |
I can remove that Hydramatic in an hour or less.
Do you have a Park position ?
The difference between inlaws and outlaws? Outlaws are wanted |
Hi Steve, No mine doesn't have the Park marked on the quadrant, it is the earlier type with park in the reverse position. John
Easy transmission to remove by itself.
