Old 06-11-2018, 10:47 AM
incommunicado incommunicado is offline
Default 67 GP dash wiring help
I am in the final stages of putting the car back together after a total frame off. In the process, I added a ralley gauge set-up that the car didn't previously have.
The gauge set is all restored, and it came with the dash wiring harness. I still have the old gauge set and wiring harness to make comparisons. The one with gauges has an extra plug that "Y's" off app. 6 inches from the main plug at the ignition switch that the original did not have?
I tried cranking the engine for the first time and I got nothing. I put a jumper wire in the extra plug between the 2 purple wires and the engine will crank. The purple wire is the ignition start wire to the solenoid.
Does anyone know what this extra plug is for? I can find nothing in the factory manual nor in the wiring diagram(s) that I have.
Pic 1. Note extra plug with jumper wire on purple to pupple
Pic 2. Ignition switch with plug on far left and extra plug?
Pic 3. Same as 2
Pic 4. this is the original harness (with std lights Vs gauges), does not have extra plug?
Name:	GP 16 6-11-18.jpg
ID:	485201   Click image for larger version
Name:	GP 15 6-11-18.jpg
ID:	485202   Click image for larger version
Name:	GP 14 6-11-18.jpg
ID:	485203   Click image for larger version
Name:	GP 18 6-11-18.jpg
Old 06-15-2018, 11:24 AM
Default 67 GP wiring help
Anyone have any thoughts or guesses?
Old 06-15-2018, 11:39 AM
Old Goat 67's Avatar
I'm pretty sure that connector in first three pictures is for a console shifter car.
Old 06-18-2018, 11:27 AM
vidguy's Avatar
vidguy vidguy is offline
I think Old Goat is right. And possibly that jumper you put in closes the shifter Neutral Safety switch.
James
Work
'67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake."
'75 Formula 400 - Daily Driver -
Running with my Home Built 455 and TH400
Details here:
http://forums.maxperformanceinc.com/...d.php?t=588372
Old 06-20-2018, 12:31 PM
I guess that make sense for an auto console shift car?
I have to wonder though what the other connections are for? At lease 2 of them are "hot" with the ignition on.
Thanks again for all the help. I am trying real hard to get the car done in time for Norwalk. Anyone want to earn a few extra bucks and help me finish it up?
Old 06-23-2018, 10:55 AM
The two purple wires are obviously for neutral safety switch.
Green is back-up lights. One of them should be hot with the key on.
One that looks gray would work with dash lights and be for shift indicator.
IDK about the other hot wire unless it went to TH400 kick down switch.
Clay
All the federales say,they could've had him any day
They only let him slip away, out of kindness...I suppose
Poncho & Lefty
Old 06-25-2018, 08:37 AM
mr67gp mr67gp is offline
If I were close I would be happy to stop by and help.
Jim K in PA
1967 GP HT 428
1967 GP convert 428
1957 Chieftain 4D HT
Old 06-25-2018, 10:31 AM
The two Purples are NSS which you have already figured out.
Two Greens are Back up light switch connections.
Grey is Shifter Indicator bulb lighting.
Orange is Console Glove box light power.
The two that should be hot at all times are one of the Green ones and the Orange, right?
Grey should only be hot with the lights on, and one of the Purple ones when switch is in start position.
Old 06-25-2018, 11:44 AM
Many thanks for all the responses and you guys continue to be a huge help. I am getting closer to finishing this jigsaw puzzle.
Old 11-06-2019, 02:29 PM
Gauges are all working, one small problem, the ammeter reads backward? It reads negative when the engine is sped up? I double checked the alternator output and it is working properly. Any ideas?
Old 11-06-2019, 06:11 PM
If it's charging correctly, charge goes up with rpm increase, wires are reversed on the back of the guage. Or wires are swapped in the holes where the harness plugs into the car.
Clay
