Old 10-30-2020, 09:04 PM
grd777 grd777 is offline
Default what is this part
looks like a sending unit on the pass side . i also have one on the drivers side
Name:	IMG_3896 (002).jpg
Old 10-30-2020, 09:31 PM
OZZIEVILLE 67 2 door's Avatar
OZZIEVILLE 67 2 door OZZIEVILLE 67 2 door is offline
I'll have the first guess that its a water temperature sensor, John L.
Sent from my SM-T585 using Tapatalk
Old 10-30-2020, 09:52 PM
have this on the driver side
Name:	IMG_3897 (002).jpg
Old 10-30-2020, 09:55 PM
Now that 2nd photo looks like an oil pressure sensor, just my guess , I'm sure I will be corrected if wrong
John L.
Old 10-31-2020, 09:16 AM
fbody_mike's Avatar
fbody_mike fbody_mike is offline
The first Pic is a water temp switch, for a warning light or emission devices. Maybe TCC since this is a 72.
The second Pic is a water temp sender. This is for the gauge in the dash.
I built it one piece at a time and it cost me more than a dime.
Old 10-31-2020, 12:09 PM
necdb3's Avatar
necdb3 necdb3 is offline
It is for the Transmission controlled spark(TCS) system. Are you going to use that system? You will have a plug in your harness for it.
Old 10-31-2020, 12:48 PM
not sure yet is that for a auto tranny . i have converted to 4 speed
Old 10-31-2020, 03:55 PM
necdb3's Avatar
Both would have it from the factory. the component that changes would only be at the trans.
Old 10-31-2020, 04:30 PM
ok so the factory installed both ,but only used one depending on the car you ordered
Old 10-31-2020, 05:17 PM
Auto and stick both had switches that worked with the extra temp switch in the head. Along with a handful more gadgets, wires, vac hoses.. that controlled vacuum going to the vacuum advance on the distributor.
This would be an all or none deal for me.
Clay
Old 10-31-2020, 08:32 PM
necdb3's Avatar
Automatic had a switch that would trip at 38mph, a manual had a switch for 4th gear. Being you switched to a 4spd. Does the 4spd you got have a switch in the side cover where the shift levers attach?
Old 10-31-2020, 09:47 PM
will check and let u know
Old 11-01-2020, 09:20 PM
is this what you mean
Name:	IMG_3913 (002).jpg
Old 11-01-2020, 11:21 PM
necdb3's Avatar
Yes, the harness should connect to that switch. That switch should be grounded unless the transmission is placed into 4th gear.
Old 11-01-2020, 11:58 PM
Formulabruce's Avatar
TCS, Temp controlled Spark. You do NOT want or need this working on your car. More things to go wrong and it was not designed to work with fuel that burns hotter, and advances that are more advanced than stock.
Old 11-02-2020, 03:25 AM
should i just plug the hole in the block/head then . or install the sending unit and not hook it up
Old 11-02-2020, 10:41 AM
necdb3's Avatar
It doesn't allow additional advance, it does just the opposite. It removes advance by turning the vac advance off unless conditions are met. If the system is disconnected, it will leave the vac advance working all the time. That's not a bad thing, but if your goal is to have the car work as it did from the factory (to factory specs) you would hook it up. It is an emission control device.
Saying that, the engine will run better with it disconnected. Disconnecting it from any electrical connection will turn the system off.
Old 11-02-2020, 09:41 PM
is the one for a 72 a 3 prong or a 2 prong
Old 11-03-2020, 09:14 AM
necdb3's Avatar
3 but only 2 prongs used
Old 11-03-2020, 06:15 PM
thank you for your help on this
