Old 01-17-2020, 03:34 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Originally Posted by ponjohn View Post
... How bad do the opposing valves limit the camshaft?...
Sorry I don't remember a number from when Mark showed me a vertical-plane drawing of the chamber/valves. I only remember that it was significantly greater than the .220" limits of my early hemi (no collision at <.220" regardless of cam profiles or lobe separation or phasing).
  #62
Old 01-17-2020, 09:09 AM
Stan Weiss's Avatar
Originally Posted by Scott Roberts View Post
So stan... you're a numbers guy... we have been a 3.78 @ 198.... what's the h.p. .... that's at 2350lbs...
Scott,
There are a number of factors to my simulations which I don't have. Also like dynos vary from one to another my simulation could vary from other methods of calculating HP. Does your time slip look anything like this?
60 Foot ET = 0.9832
330 Foot ET = 2.5338
1/8 Mile ET = 3.7803
1/8 Mile MPH = 198.4429
Stan
Pontiac Pump Gas List
  #63
Old 01-17-2020, 03:57 PM
Cool
I'm nobody of any particular relevance, as younz know, but there is this 426 Nascar Hemi 4-speed i've been pushing awhile. Ran bigly when pulled in 1973 Talledega race by some Pontiacs guys. 30k only needs carb and shifter-handle to run like a Butler Pontiac. Penske-built from 69 HEMI stuff. note the intake style.
I want it but was told it doesn't come close to fitting a 68 GTO. Sooooo,
Who wants it.....
ID:	528990   Click image for larger version
ID:	528991   Click image for larger version
ID:	528992   Click image for larger version
  #64
Old 01-17-2020, 06:02 PM
Scott,
60 Foot ET = 0.9832
Stan
Yes, similar.
  #65
Old 01-17-2020, 06:41 PM
tom s tom s is offline
HIS,I have the correct carb for that engine!Tom
  #66
Old 01-17-2020, 11:44 PM
Scott,
60 Foot ET = 0.9832
Stan
What other info do you need?
  #67
Old 01-17-2020, 11:50 PM
Engine//Trans still avail.
  #68
Old 01-18-2020, 09:46 AM
ponjohn's Avatar
ponjohn ponjohn is offline
KRE showed the intake for the hemi billet heads.
  #69
Old 01-18-2020, 10:51 AM
Stan Weiss's Avatar
Scott,
My software is very conservative. HP and torque are not calculated by the simulation but are inputs. I have posted the HP and Torque curve that I used to simulate your run. I am sure that you have data logging. I get a peak of 2.99 G's from the simulation.
Stan
  #70
Old 01-18-2020, 01:41 PM
GTOGEORGE's Avatar
Billet intake, gotta love it!
GTO George
  #71
Old 01-18-2020, 01:57 PM
Stan Weiss's Avatar
Be interesting to know what the dollar cost per HP is on this build.
Let me add:
I don't do FaceBook so I have no idea what is posted there.
Looking at this build I have to wonder if this not a one off or it is just one of a couple. If anyone talks to KRE, I would be interested to know if there is even a cast version of any of these parts. Like heads and blower manifold.
Stan
  #72
Old 01-18-2020, 08:35 PM
ponjohn's Avatar
Maybe the billet is proof of concept then make a casting from the finished revision.
  #73
Old 01-19-2020, 03:12 PM
Rusty4cyl's Avatar
Rusty4cyl Rusty4cyl is offline
Billet blower intakes are very nice. I have a billet 4 cyl blower intake
Blown 4cyl's to the front
  #74
Old 01-19-2020, 08:03 PM
Dragncar Dragncar is offline
One of the things Jeff told me this build will take car of is the valves hitting each other. He is aware of what people are saying about it.
I hope this can be the start of something much bigger for Pontiacs for heavy hitters.
I would like to see their billet RAV head up and running too. We all know what the Boss Bird has done with billet RAVs.
  #75
Old 01-19-2020, 10:14 PM
What are people saying about them?
  #76
Old 01-19-2020, 11:51 PM
Stan Weiss's Avatar
I sure would hope so. I talked about that happening on a Hemi that came out in 1964. I sure hope something has been learned since then.
Let me also add
The Crane cam that I was talked about had 296 degrees duration @ 0.050" lifter raise.
Stan
  #77
Old 01-20-2020, 01:42 AM
Let me also add
Stan
He said they are going to make sure nothing hits with the build. I have no idea how similar this is to a Chrysler Hemi but I bet with big cams things get close.
The old MT heads did not flow that much, maybe this will prove a good starting going to making serious power down the road.
No one makes more serious Pontiac race parts than KRE.
  #78
Old 01-20-2020, 09:03 AM
Kre has stepped up their game from when I dealt with them 15 plus years ago. They do have a good selection of parts. Quality castings maybe these day's ? I have not even looked at their stuff in years. I believe the reason the Butler's never made their own head was the e head did what they wanted it to and it was a bad investment.
  #79
Old 01-20-2020, 09:06 AM
mysticmissle's Avatar
this is Dill Brandow's hemi is it not? He has had this in the works for some time. Making the dream come alive with KRE
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
  #80
Old 01-20-2020, 09:34 AM
GTOGEORGE's Avatar
Yes!
GTO George
