Where does this go
This bracket or part is for dash part # 10013086 Firebird W/ air 1980-81 Says on online parts lookup I / P insl Pnl Mt. Think under dash maybe gauge cluster.n
I have neither diagram or picture of it, other than what you have.
can you post a pic of it?
Steve F. |
Where does this part go
Some place at dash cluster says on parts look up Says for 1980-81 Trans Am w/air
I just added second part some kinda spring clip think again something with rally dash cluster
Mounts off the fuse panel, hanging off the underside in this shot. Perhaps the plug slides onto it to hold it out of the way.
1980 Firebird fuse block by Aus78Formula, on Flickr the clip holds the drivers air vent in, shown here on the inside looking out. Pull the spring retainer, and the swivel section is allowed to lift up and out of the surround. Dash vent and clip Firebird Dside 4 by Aus78Formula, on Flickr Last edited by Aus78Formula; 01-24-2019 at 05:10 AM. |
Great pic of the clip on the vent Aus78! I didn't know that one.
Here are pics of the angle bracket screwed to the left lower corner of the fuse panel, using the screw that holds the fuse panel to the firewall. This little bracket is used if you are using a "hush" panel above your pedals. The hush panel would screw to the bracket in that corner, as seen in the drawing. And the hush panel also screws to a hole in the upper part of the gas pedal mount, and the a/c duct that runs under the steering column. DSCN0646 - Copy by grand73am, on Flickr hush panel by grand73am, on Flickr
Steve F. |
No worries
Looks like the console adapter
JIM |
maybe if I actually looked the drawing . It mounts some plastic covers under the steering wheel
JIM |
Yep, confirmed a year ago.
Thread Tools | |
Display Modes | |
