Old 02-23-2023, 12:30 PM
Kenth's Avatar
Kenth Kenth is offline
Default Frankencarb (again).
For $6500 one should be able to ask for the carburetor to have the original throttle plate and not parts from a Carter made aftermarket Quadrajet.
https://www.ebay.com/itm/33404855668...Bk9SR7TOjvHPYQ
JMHO
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 02-23-2023, 04:50 PM
turbo69bird's Avatar
What makes you say it’s a aftermarket?
That’s a member on here’s listing he’s a pretty knowledgeable guy
960 HP @ 11 psi, 9.70 at 146.
Old 02-24-2023, 12:59 PM
Kenth's Avatar
Then he should know Carter never made any Ram Air Quadrajets or parts, donīt you think?
Carter logo on throttle plate and floatbowl vent housing. Carter stamped # on throttle plate intake side.
Throttle plate is from a Carter 1967 6132S aftermarket Pontiac Qjet. There are no drilled holes in plate for idle bypass air in the 1968 and later casting style for this unit, BUT hole is drilled for ignition manifold vacuum advance port.
Also, the holes, uneven distance to edge, drilled in throttle valves are not factory holes.
Description from ad:
"1970 70 FIREBIRD TRANS AM GTO JUDGE RAM AIR III IV ORIGINAL production CARBURETOR. 7040273 WC 1040 date code .This carburetor has been professionally restored all correct and original numbers for Pontiac ram air application in 1970."
Obviously false, thus a "Frankencarb", as 99% of all RamAir carbs are on the "bay".
FWIW
ID:	607797   Click image for larger version
ID:	607798   Click image for larger version
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 02-24-2023, 02:39 PM
Ok well that answers that question . Just wondering what you’d picked up on and now I know. ��.
Old 02-26-2023, 09:17 PM
Dont _____ me Dont _____ me is offline
I have one for sale for 5k.
