"Is this right" questions
Should the heater house to pump go close to the exhaust or past the a arm?
Is the lower rad hose on correct? Does the heater house to block loop up over the other hose? Why would they send me sick a long piece? Is the ground strap correct? Is the top rad hose correct? It seems like the alt bracket is hitting. What go on these two vacuum locations? Sent from my SM-G860P using Tapatalk
http://www.outlawpontiacdragseries.com |
you are missing the bracket that goes to the front of the pass head for the heater hose.That hose should be a lot shorter.Tom
I think the adjusting arm on that alt goes to the timing cover allowing the alt to go lower and toward the timing cover.Tom
I think if you get the shop man for the year of your car it will show where this stuff goes.Tom
yes you need a bracket for the hose, it bolts to front of the passenger head. The alt bracket has 2 pieces one to the thermostat housing and one to a bolt on the water pump / timing cover. I believe there should be a nipple on the back of the passenger head for a hose from or to the heater core. This pic shows the 3 brackets...
If you have a.i.r., the alt bracket is attached to the a.i.r. bracket. There isn't a separate bracket going to the water neck. The a.I.r. Pump does use one of the neck bolts to mount to.
I need to get that bracket for the front of the head for the heater hose. Sent from my SM-G860P using Tapatalk
Hi
Here is a spare
from a 70 350 no air car .... 16.50 shipped Scott |
http://firstgenfirebird.org/forums/u...&Number=307336 http://firstgenfirebird.org/forums/u...&Number=307342
1968 Firebird 400HO convertible 1971 Trans Am 4-speed, white/blue |
Scott, is that bracket from 70 the same as 67?
Hi Jason. I used a 68 GTO heater hose for the rear hose from the head to the core. I had to trim off a few inches, but the fit looked a lot better than a regular piece of hose, all looped over. Even if it is, I never thought that looked "right".
https://www.npdlink.com/store/produc...180-10419.html
1968 Firebird 400 RAII M21, 3.31 12 bolt, Mayfair Maize. 1977 Trans Am W72 400, TH350, 3.23 T Top Everyone you will ever meet knows something you don't. Bill Nye. |
So the 67 had the head bracket only? Nothing on the inner fender?
Correct.
Is this regulator installed in the right holes? Were they held in by these type of regular screws? Was the condenser held on by the one of three screws? Share did the ground go to? Thx
Correct mounting bolts look like this .https://secure.amesperf.com/qilan/De...A&web_access=Y
http://www.firebird400ho.com/photo-g...ppa-photo=1790
Thanks Ted. Where is the radio cap mounted in that picture?
Also,... What is this part?
Should be mounted on the right side bolt.
Looks like AT linkage for column shift. You need to remind me what car you have? 67?
67 fb 400 4 speed muncie, 3.36 posi, ms, mb,amfm,a.i.r., mafair maize, black deluxe int, black landeau.
Not sure where I got that part, lol. Sent from my SM-G860P using Tapatalk
Mayfair Maize...Great Color!!
