73-77 A-body TECH Includes 73GTO, LeMans, Grand Am, Can Am
Old 05-13-2022, 04:54 PM
Flashflood Flashflood is offline
Send a message via AIM to Flashflood Send a message via MSN to Flashflood Send a message via Yahoo to Flashflood
Default Need help motor mounts 403 oldsmobile
I need help finding 403 motor mounts ames has the ones for the earlier models. Or ones without the olds motor in it any help.
Sent from my SM-S506DL using Tapatalk
Old 05-17-2022, 11:55 AM
Are you looking for the "captured style" mounts that bolt to the engine crossmenber? And use the brackets to mount to the engine block?
If so they should be the same for an Olds 350 or 403 V8. Rock auto lists them in stock for example, They should be available from many other sources as well,
https://www.rockauto.com/en/catalog/...tor+mount,5552
Old 11-07-2023, 10:26 AM
Trevor78 Trevor78 is offline
Never returned to other posts either.
