Members Helping Members help Buying a non Pontiac item, transportation help, Handy-man advice, directions, vacation ideas, places to dine, ebay and generally anything you think might help other members. |
'03 Jeep Wramgler 4.0 misfire problem
Any Jeep techs?
My Jeep has suddenly decided to misfire. For several years have been getting a code for TPS. CEL would light up, but come and go on its own. Seemed to stumble at idle on rare occasion, set the CEL, then go away. So I ignored it. A few months ago, my son who drives it started experienced a momentary very high idle on start up. It was intermittent. Wouldn't happen every time. My recollection was no code. Just would rev to maybe 2000 for a second or two then return to normal idle. I told him to spray the throttle body good with Throttle Body cleaner. He did and that problem went away. That was months ago. Last Sunday, he was here. Hadn't changed the oil in awhile, so we did that. On the way to get the oil, he noticed it was vibrating abnormally, I sensed it was running a bit rough. I didn't think much of it, He filled the tank with gas as I got the oil. We changed the oil. He then headed home, got to the highway. He said it was running poorly so he pulled over. Check engine light on, would flash on occasion while trying to accelerate in higher gear. I went to meet up with him, drove it to parts store. Seemed to rev fine in neutral. Checked codes. They said misfires on cyl 2 & 6, plus TPS. He told me original plugs were std copper. 86,000 miles on them. He suggested misfire was probably tune up, told me to start by changing plugs. Engine has a coil pack right on the plugs, no distributor or plug wires. I installed Autolite Platinums. Seemed to run fine at low speed in 2nd gear. But took it out on the road, and it stumbles. Seems to accelerate fine in 1st 3 gears, but if I cruise at 50 in 4th or 5th, then drop back to about 40, then try to accelerate hard, it will misfire, hesitate, no power. Seemed "better" than before the plug change, but definitely something still not right. So next thing I did was change out the TPS using NAPA part. Had to remove the TB to get the screws out so cleaned the TB while it was off with Seafoam that I bought "just in case". It was pretty clean and the intake below the TB looked brand new (left it alone). Took it back on the highway. Same symptoms. So next I poured a can of B12 Chemtool in the full tank. I then sprayed the rest of the Seafoam thru the TB following can directions. Sprayed it in with idle about 1700. Let it soak with engine off about 5 mins after can was empty (they said 1/2 can but I already used some to clean the TB). Back on the highway. Same symptoms. Took it back to auto parts store. Read codes for random misfire, misfires on 2 & 6, and a TPS code (weak signal I think). I think these were same codes as before, not sure about the random misfires, couldn't remember if they said that the 1st time. So I had them clear the codes to see what might come next. Guy suggested it could be Idle Air Control. Said to disconnect it and see what happened to idle. I drove off. No codes set, but it was still stumbling a bit. I pulled over, disconnected the IAC. Didn't seem to change the idle to my ear. I rev'd it at idle, seems to rev fine. Drove back to parts store, no codes. Bought can of TB cleaner. 2nd guy came out to car, took a look, recommended to check for vac leaks. Drove home, lots of stumbles, misfires. No CEL at least for awhile (8-10 mile trip home). But somewhere near home it set the CEL. I didn't notice it until I pulled in the driveway. I had my wife watch the tach as I sprayed around. No change in idle speed. Didn't spot too many possible hoses to spray. I did fix a break in the vac line for the cruise control, but it had no affect on the idle even when disconnected. So I pulled the TB again, removed the IAC. It was bit crusty with carbon. I cleaned it up real good, cleaned the passage in the TB. Put it back together. Same symptoms. I plan to check to see what code has been set. I'm guessing misfires again. Maybe the TPS (could the NAPA part be the culprit?). I wondered about bad gas but I think the vibration we felt before filling up was probably an indicator that there was already a problem. What do I do next? Unless I get a different code, I'm at a loss. Hate to throw parts at it. Would a diagnostic test be able to pinpoint anything? Help! |
A defective airbag clockspring in the steering column will cause those irregular misfires, and high idle, since a bad clockspring will cause a spike in voltage in the TPS because of the fact that they share the same reference voltage inside the PCM. This is more common on the Wranglers with the roof removed since rain water will wreak havoc on the clockspring. I had a bad one in a '01 Cherokee that caused the exact same symptoms as you are experiencing.
1976 LeMans B09 Freeway Enforcer, 455/M40 Smokey 1977 Trans Am, 400/M21 Black/Gold Bandit. 44K actual miles 2017 Sierra SLT 1500 Z71 4X4 2019 Canyon SLT Crew 4X4 |
77, thanks a bunch for the input.
That is interesting, hadn't considered that. Top is rarely off, occasionally on a sunny day. For most of its life, it wore the hardtop, but the soft top has been on steadily the past 2 years. You say you had same symptoms. But my intermittent high idle on start was resolved by cleaning the TB. I think was caused by a sticking IAC. Until this past weekend, it had been running/idling with no issues since the TB was sprayed. I do sense a bit of a rough idle now. I started it cold this morning and just let it idle a few minutes. At start up it idles just about 1000 rpm, maybe a hair over the line. As it warms up, it settles down to the 2nd dot which I judge at about 700 rpm. I think this is normal idle speed for the man trans motor. But I do feel some "throbbing" roughness". Not a lot, just enough to say it doesn't feel silky smooth. From what I read, the clock spring will also affect horn & cruise. Do you know if your horn and cruise stopped working? Any air bag light? I ran it on cruise yesterday at 50 mph, worked fine. Hit the horn this morning to test, it worked. No air bag light (except the start test cycle). Do you know how to access the connector for the clock spring? I read that I could disconnect it and determine if the clock spring was at fault or not. Symptoms go away, replace clock spring. Symptoms remain, look elsewhere. I also read that I might be able to pull the horn relay to see if the clock spring is the problem. I did pull the horn relay, still has the roughness at idle (I didn't drive it on the road). I'd like to be able to test it for a bad clock spring before replacing, I understand it is a pricey part. Can the clock spring affect engine performance without causing the other problems (inop horn, cruise, air bag light on) Your thoughts? |
That Cherokee did have issues with the cruise and horn not working. Did not have an issue with the air bag light coming on. The clockspring should be considered whenever this problem pops up on a Jeep. BTW, the horn/airbag can still work, yet cause TPS voltage problems. I have also heard about defective horn relays causing the drivability issues on this era Jeep too.
Well, don't know what to think. Cruise & horn work fine. There is a break in a vac line that controls the vent doors. That line broke a few years ago, I duct taped it together, it's been fine since, but I did just repatch it with a pc. of rubber hose "just in case". But still nothing changed.
About 3 years ago, I pulled the fog lamp relay because the multi function stalk was turning the fog lamps on with the switch off. So I pulled the relay and it has been out since. Don't think that can be related at all. I mention this because I just made an appt to bring it to the dealer. If it is the clock spring, I just don't want to fool with it (I've read the write ups for replacement, just not up to it especially being unsure that is my issue) and figured I will have them repair the multi function stalk at the same time. I expect a big bill no matter what and will report the outcome. Sad day for me, been a long time since I've thrown my hands up and handed a problem off to the dealer. They can't take me in til Monday so I will have the codes read over the weekend just for yucks and because I won't go down without a fight. But my wife gave up her car so my son could get home and she wants to swap back ASAP. So I am about out of time. |
Id try an ignition coil,about $100 and easy to change,more than likely that's the cause of the misfires.
The first thing I would do is hook up a scanner and drive the car reading the data stream. Freeze-frame data at the time of misfire will let you see what the ignition voltage output is for the suspect cylinders at the time of the hiccup. I agree with Skipp65, very probably a coil/plug boot problem (the boots like to short to ground). A TPS and idle control motor would have absolutley zero impact on a misfire condition going down the road. ZIP. And the liklihood of an injector problem is extremely rare. Check your ignition events with a scanner or DSO, that's where I'd begin.
Jeff |
I believe #2, #6 are paired cylinders in the coil pack. Another vote for a coil assembly. If you ran the plugs 80 k without changing, you probably killed the coil.
I would also repl the tps sensor , as it has set codes multiple times and wiill cause hi idle issues. This comes from a ex 15 yr mopar tech, try to use oe parts also, try to stay away from the aftermarket on driveability parts. One other note, I like autolites in my hot rods, but perfer champions in the mopars. John Last edited by BB70; 07-03-2013 at 07:07 PM. |
Me and everyone in the family loves jeeps and the only problems have been iac and egr sticking. Where talking 2-3 hundred thousand miles and still going. Still got my 73 cj5 with AMC 304. No misfires just sluggish and poor idle
Guys, thanks for the comments.
I made a new appt at another dealership for Fri morning. Wife wants it fixed before Mon, she has to have a car next week. Recall, I erased all codes. New CEL shows single code P0302, #2 cyl misfire. It seems the problem is best described like so. Bit of a rough idle, but steady and normal rpm. Accelerates in low gears pretty strongly with what I would call light throttle. Hesitates badly, misfires, will even sound like a backfire with heavy throttle when trying to accelerate in higher gear from about 40 mph. If I use light throttle, have taken it up to 55 mph with pretty smooth acceleration. So it seems it is only when I try to open the throttle more heavily in higher gears that I get the misfire. I'm beginning to "like" the coil pack idea. I'm wondering if maybe I didn't get the boot seated real well on one (or more plugs)? Or maybe you are right, the old plugs killed the coil pack? So I have 2 choices, throw a new coil pack on it tomorrow. I plan to pull the coil pack to at least inspect the boots and reseat. If reseating the boots doesn't fix it, I'm not sure I'll try replacing the coil pack. Might just hand it off to the dealer Fri at 8 am. I'll sleep on it and make the decision. Thanks again, and I'll report back. |
Does this have six coil packs? One for each cyl. You could swap the coils around to different cylinders, then see if the diagnostic readout for misfire "moves" to the appropriate cyl. Just make sure you clear the old codes out before you run the engine. I'd try this before I resigned it to the dealer. |
Unfortunately, I think the coil packs are not individually moveable.
A single "rail" assembly with 6 rubber boots attached. The boots are separately serviced. I think there are 3 coil packs built into the rail, don't think they can be moved around unless somebody knows different. I will pull the rail and look. When I changed plugs, I didn't disconnect the rail connector, just pushed the rail out of the way. I'm thinking I might not have gotten the boots seated correctly by doing it this way, so I'll pull the rail, disconnect the connector, inspect, and reinstall. If the coil packs can be moved I'll do that. Otherwise, I'll look for some sign that the boots weren't seated. Thanks. One other thing. I see lots of Jeep guys claim the Autolite AP 985 single platinum doesn't work so well in the distributorless 4.0, tell you to use the APP 985. That doesn't make sense to me because I think the only difference is more platinum. But since I used the AP 985.... Opinions? |
This is the best post I could find about the problem with the AP 985.
http://www.jeepforum.com/forum/f9/ap...29/index3.html |
Was thinking of joining that Jeep forum, as of late. my son's XJ has been a little diversion project, was bought as something for him to cut his teeth on mechanicall. In purchasing it, we purposely avoided the last of the XJ's, the 00's & 01's, due to DIS & redesigned cylinder head. Talked to a 15 year Jeep tech yesterday & he wasn't that down on DIS. Hope this turns out as inexpensively as possible for you John.
Woo-hoo, happy 4th!
Thanks everybody. So this morning I decided to take a swing at it. I found another post that went into more detail on the reason for the Double Platinums. Had a few folks tell me that I was better off with the O.E. copper plugs. But Autolite sez... The Double Platinums were developed for the Distributorless Ignition System. This system has a coil pack that fires 2 plugs at once, meaning it is a "waste spark" ignition. When one cyl is firing, its mate also fires (only one at a time actually burning fuel, the other spark is wasted). One plug is negative polarity, the other is positive polarity. So it "needs" both electrodes to be same apparently, else the plugs will fire differently and result is some misfire issues. Single platinum are NOT recommended for the DIS as on the '03 Jeep. Finally made sense to me. The O.E. copper plugs work because they are same on both electrodes. The Double Platinums are better because they will last longer and also are same on both electrodes. The Single Platinums should not be used with a "waste spark" ignition. Now, I don't think the plugs were the problem for me, in fact I don't necessarily think the original plugs were the problem (though I'm not disagreeing with the post here that said the old plugs killed the coil pack). I now believe the original misfire was caused by a failing coil pack for cyl 2/6. So this morning I headed to NAPA, bought a set of APP 985 Autolite Double Platinums and a new coil rail. Installed the plugs and the rail. Have been driving around all day, not a single misfire. And the CEL cleared itself after awhile. It now accelerates in 4th & 5th from 40 with heavy throttle and no misfire. Thanks for all the advice here, it really helped. Although the clock spring wasn't my issue, I now know to beware of that item. So even that was valuable info. Special kudos to the guys who figured the coil rail. I still have to think about the multi function stalk, but I'll be canceling my appt at the dealership in the morning. My son better be thanking me, I even washed the thing for him. He'll get it back tomorrow or Sat. My day was complete when I took the 4 day old AP 985s back to Walmart. They gave me no hassle, I said they were wrong for my car and got my money back. Only bad news, Autolite had a rebate going thru June 30. So I lost out on that deal. OPH, thanks for the well wishes, I figure I got off as cheap as could be. Coil rail & plugs for about $140. I got this Jeep for my 2 youngest in HS. The youngest wants to keep it (he just graduated college). My only regret is that I also like it. It really has been cheap to maintain, gas is the killer. And it is about ready for tires. But I'm with you, good vehicle to learn on, pretty old school. And now that I know a little about the DIS, I kinda like it. It is really simple. I figure no plug wires is a pretty good idea. |
Glad you got it fixed, John.
The coil rail include the coils?
John, yes, it's an assembly, 3 coil packs on a single rail, with 6 boots. 4 bolts and a connector on one end, disconnect, pop the boots off the plugs. Reverse to reinstall.
Tried to tackle the multi function switch turn signal stalk today to get the fog lamps working. Apparently a common Wrangler problem, switch goes bad and fog lamps come on with switch off. So most do what I did a couple years ago, just pull the relay to prevent having a dead battery when the fog lamps go on by themselves in the driveway in the middle of the night. Simple job that turned into a bear. I screwed up and mistakenly unscrewed the ignition switch, it sprung apart before I realized what I was doing. Bought a new MFS at Autozone. $52, not too bad. Spent most of the time trying to get the ignition switch back together with a ball bearing and a spring among other parts that fell out of the switch that I had no idea how they should go back together. With a sick feeling that I was never going to get it back together, I finally sorted it out. Crossed my fingers that it would work correctly. Installed the new MFS, got it all back together, installed the fog lamp relay, hooked up the battery and now had no flashers, no turn signals, new MFS not working at all. Actually I think the headlights did work, but that was it. Didn't check the fog lamps but since flashers and turn signals weren't working, I had a sinking feeling. Only problem with old switch was the fog lamps. It did start but... Now I'm thinking I really must have screwed the pooch by disassembling the ignition switch. So I disassembled the ign switch again, cleaned everything up, thinking it must be related to the turn signals not working. Reinstall again (by now I'm becoming expert at this repair). But still no signals or flashers. So I pulled out the new part, wondering if I somehow had blown a fuse or something. Then put the old switch back in to see what it would do, signals and flashers now working. I concluded the Autozone MFS must have been defective, so I gave up, pulled the fog lamp relay, went back to AZ, got my money back. Mgr said, they don't generally take electrical parts back that have been installed, but he didn't balk too much. I was getting ready to get mad, I had spent way too much time fiddling with it, only to discover the part didn't work out of the box (most of that time admittedly my fault, job should have taken about 30-45 minutes). But even if I hadn't screwed up the ignition switch, it was still a pisser to have to do the job three times because of a defective part. Anyway, I ran out of time and they only had the one in stock so, I got my money back and with that, drove 90 miles to meet my son halfway. Jeep still running great. He got back home and texted to say it ran great for him, so all is well I guess. Just no fog lamps. Least now I know how to fix them, just need to get a good switch next time. Prolly take 20 mins with all the experience I now have doing that repair. |
John, when you installed the new MFS did you happen to leave out the flasher that get push in the back of the unit? New unit would not come with one. BTW Jeep recommends plugs every 30K.
'68 GTO '69 Corvette '75 Cadillac Coupe Deville TOM Last edited by salem1912; 07-06-2013 at 12:18 AM. |
My personal Jeep is a 1999 Cherokee, which was the final year for the good head and a distributor ignition. After all of these years and well over 100k miles, still runs like new and does not burn or leak any oil. I have used OEM Mopar parts for tune ups, and regular Champion plugs in it, changed at every 30k miles. Takes all of 10 minutes to change them, and that's if I am sipping on a cold adult beverage between each plug change.
Now I am feeling even dumber! I just watched a video and you are right. Gotta swap the flasher. No wonder I had no signals/flasher. Jeep is now gone but at least now I won't make that mistake again. On the plugs, Jeep went to NGK copper plugs. The copper plugs (Champion or NGK) is why they recommend 30,000 mile change interval. 77, the double platinums will go 100,000 miles, less time under the hood, more time for the beverages? |
