Old 01-13-2020, 05:23 PM
Dragncar Dragncar is offline
Default High Port crossover/ timing cover misalignment
Has anyone ever just made a water crossover that actually aligns with the hole in the timing cover. Just cut out the section and raised it up to match.
I do not see why it can not be done. Aluminum welding is not my thing but I could get my Lincoln 180 amp 220V welder ready to do the fabrication.
Cut up 2 aluminum crossovers and fab it together so it aligns up.
But it usually does not work well without a spool gun at least and no Tig at home. It would be ugly.
I could make one out of steel but it would not look good either.
KRE should just cast some up, I bet they would sell.
I keep hearing about the front cylinders running hot if I just plug the holes like most do. Pump gas engine, it would be a problem.
How much is the offset ? Looks like around 3/4" from the picks I have seen.
Old 01-13-2020, 05:53 PM
slowbird's Avatar
slowbird slowbird is offline
Why would the front cylinders run hot because that's blocked? Not sure who you're listening to but i'd stop listening
Old 01-13-2020, 05:58 PM
GTOGEORGE's Avatar
Ditto!
GTO George
Old 01-13-2020, 06:17 PM
The timing cover to crossover holes are just a bypass(Chevies actually have a hose there). So no big deal to plug it, maybe drill a couple of small holes in the thermostat if you are using one.
Old 01-13-2020, 07:09 PM
Hooter's Avatar
Hooter Hooter is offline
I’ve had a that hole plugged on my street and race car for years with no issues.
67 Bonneville ragtop
Old 01-13-2020, 08:04 PM
firechicken's Avatar
firechicken firechicken is offline
Mine is plugged no issues.
I wanted it plugged so all hot coolant from the heads had to go through the radiator instead of the hot bypass straight back to the engine.
Old 01-13-2020, 08:12 PM
Scott Stoneburg's Avatar
I have also had the by pass hole plugged for years. I had no negative heating issues from plugging it. I do not run a thermostat, just a restrictor plate.
Old 01-13-2020, 10:51 PM
PAUL K's Avatar
PAUL K PAUL K is offline
You can run without the bypass channel connected and you will have more uniform cooling... however if you're using a thermostat it won't open consistently. That issue can be solved by adding by-pass holes like Skip suggested.
Go fast, see Elvis!
Old 01-14-2020, 12:22 AM
Hooter's Avatar
X2 on jacking up the thermostat without drilling holes in it. Took me a while to figure that out.
Old 01-14-2020, 12:31 AM
I understand people have been just plugging the holes and getting by. But I do not think it would be hard to make one work as intended either. Anyone ever make one ?
Old 01-14-2020, 11:10 AM
tom s tom s is offline
The question to your post is why.Just does not seem the "juice is worth the squeeze"Tom
Old 01-14-2020, 12:11 PM
Mark G Mark G is offline
Well said Tom ..lol
Old 01-14-2020, 09:52 PM
gtokid1968's Avatar
gtokid1968 gtokid1968 is offline
If I am getting this straight, most of you guys are running lines from the back of the heads to the crossover under the thermostat and blocking the front holes that were for the crossover?
Old 01-14-2020, 10:35 PM
Hooter's Avatar
That’s what I do.
Old 01-15-2020, 12:37 AM
janderson's Avatar
janderson janderson is offline
What is on mine:
The crossover and timing cover are both plugged where they would meet.
Restrictor in crossover in place of thermostat.
-8 lines from rear of heads (connected above restrictor) to outlet housing.
Old 01-15-2020, 06:15 AM
chuckies76ta's Avatar
Originally Posted by janderson View Post
What is on mine:
Any chance you could post pics of your setup. Thanks
Old 01-15-2020, 06:18 AM
I though about this if I would have run the HP heads. My son is a welder and what I was gonna do was straight cut across the bypass, then lower it to match timing cover, then Aluminum weld together. I think it's an easy fab job.
Old 01-15-2020, 06:21 AM
Originally Posted by Hooter View Post
That’s what I do.
Can some of you guys explain the benefits of blocking the cross over, then running lines from the back of the heads to the cross over.?
Old 01-15-2020, 10:59 AM
janderson's Avatar
What is on mine:
Only pic I have on my tablet.
If you need more detail, I can probably dig something up.
Old 01-15-2020, 11:03 AM
janderson's Avatar
Only pic that I have on my tablet.
