Dash Wiring Harness
Is the dash harness the part that comes with the fuse box? The previous owner of my car hacked up the wiring so much that I gotta start over....
Yes the dash harness will have the fuse block with it. If you're replacing everything there are an assortment of add on harnesses as well.
Just out of curiosity how bad is hacked up. The reason I say this is I was disappointing in the quality of the replacement wiring I bought. I think I could have done a better job making one up myself. The harness for the dash is the most expensive one. So say you need to rerun half of the wires in that harness which is like what six wires repair might be something to look into.
I'm pulling it all out to day to see what's missing....or worse yet.. what was added!!
You can also have your original refurbished/built.
Where at?
American Auto Wire. M & H might do it as well, along with others out there.
M&H make excellent harnesses. I purchased all of mine from them.
67 Firebird Convert 455 +.060 TH400 74cc KRE d-ports piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.50 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s |
