68 Lemans OHC 3-speed parts wanted..
This is for a ONE BARREL carbureted OHC/manual transmission. I'm looking for the following parts:
-Air cleaner assembly (68-69) -Choke rod -Exhaust manifold (must be real nice with heat riser valve, bimatallic coil,return and anti-rattle springs in tact. -flywheel inspection cover - "OHC" rocker molding emblems |
i have a mint cleaner
Mark.. The Goat whisperer "I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered." |
If you can't find what you need I have a complete set up from a 1bc project that I never got to complete. Note this ex/man has no gate from the factory.
I'll look and see if I have any loose parts as well.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
pretty sure I would have one too
but I wont separate the intake/exhaust manifolds. Do you have correct carb? also have a few air cleaners in varying condition. Jeff that setup looks nice!
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
Very sharp looking Jeff! I think the heat riser was eliminated after April 68. My car is a Dec. 67...My carb is the manual type Monojet, single float, not the dual float type like yours. My carb won't work on that intake. The manual intakes are different from auto intake and leave huge vacumm leak gaps at the base. It is a nice setup though and I appreciate the response.
I'm not fully aware of the Diff MT vs AT 1BC mans.
I'll have to check my other intakes. Like yourself it took some time to locate an exhaust man that wasn't cracked. That is why this set up is a little bit hodge podge. '66 carb, 67-69 intake, and '69 exhaust. I did find another decent choke.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. Last edited by Jeff Hamlin; 11-12-2013 at 07:53 PM. |
seems like I bought a filko choke for one a few years ago
maybe find a NORS I know Ive got a few complete 68 M/T motors but not sure I want to separate just for exhaust manifold. Ill check and see what loose ones I have. I,like Jeff,am not so sure of a different manifold for a M/T. Parts book shows one replacement #9794231 for all 66-9 OHC-6 1bbl. Perhaps its only the base plate gasket thats different. I just cant imagine having two different manifolds,one for auto and one for manual trans.
GASKET
I think it may be the gasket if you look close this is an NOS set of gasket(s)
It has vacuum reliefs and is clearly two gaskets that are stapled from the factory so you know not to separate. Don't know why they couldn't make a one piece thicker gasket ?
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. Last edited by Jeff Hamlin; 08-12-2013 at 05:07 PM. |
I had an intake that had the small openings in the casting like the gasket. But, it wasn't the gasket, it was definitly the intake casting. It was an odd manifold. It was on a 68 motor that I eventually sold after I swapped the intakes
Had a chance to check my other 1BC intakes and they are all 9794231 68-69 all same as above.
I'll keep checking though, I always come across parts so always nice to know what & why. I did also find another choke thermostat and several rods of varying configurations. They are both the same choke the pic make the NORS unit look larger. The used one is in great condition just dis-colored. LMK if any may be of interest
i havent forgotten to get pics, i havent had internet for 2 days, my company shut my service off by accident..i will work on it tomnorrow
What a bummer! No problem, Marx..Whenever you're able. No hurry. Thanks -Gary
Heres pics...not sure the riser tube is correct, cant find the fan, but will look some more..flapper works too
GTM,
Parts on the way. Thanks.
Thanks Jeff!!
