The motor I had in my Firebird was a Chev 250 straight 6, So I assume just change the cone on the starter it should fit the OHC?
I'm not a starter expert but think you should be good.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
I used a Buick 455 starter with an OHC nose cone on mine. 90% of GM starter motors between at least the mid-60's to late 80's are the same dimensions with the nose cones being the difference. Big block starters tend to have more windings in them for more torque. So theoretically the starter doesn't have to work very hard to crank the engine over.
__________________________________________ "How I learned to stop worrying and love the OHC Pontiac L6" The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!) 1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!) |
The Following User Says Thank You to TheSilverBuick For This Useful Post: | ||
I was looking through Summit racing website looking for a HEI Distributor they have one and it says it will fit for $369.00. Davis Unified Ignition GM Racing D.U.I. Distributors 617211BL
Doubtful. Be careful that many/most of these type companies list products for the OHC when they are all just Chevy 6 crap.
69 OHC ZH Sprint Hurst 3 Speed 3:55 (1 of 213) 99 Valkyrie 1520cc Flat 6 108hp/110tq - For Sale http://sohcsix.yuku.com/forums/1/OHC-lounge Wanted: 1969 OHC "H" Camshaft |
The Following User Says Thank You to PMD1969 For This Useful Post: | ||
This is another way to simplify the ignition.
Install this in the Dist and be done with points. http://www.ebay.com/itm/171240364226...3AMEBIDX%3AIT#
I bought the starter form Jeff and it wont fit because of the depth, Jeff and I have been e-mailing back and forth trying to figure it out. we're both stumped, figuring the bellhousing but that don't make sense, I don't want have to pull the motor out. Unless I go with a gear reduction starter for 200.00 some odd dollars. Anyone else have any idea's?
