Old 03-12-2019, 08:32 PM
68hotbird 68hotbird is offline
Default King main bearings oil hole modifications
My first set of king main bearings should I do the oil hole modification like I do on the speed pro bearings with the oil slot or just leave the single round hole. Will be a 6800 rpm drag motor.
Old 03-12-2019, 08:41 PM
GTOGEORGE's Avatar
I did........er I did my own mods to the holes.
GTO George
Old 03-12-2019, 09:31 PM
Dragncar Dragncar is offline
Yes, I take a Sharppie and mark the hole in the block on the tab side and transfer. Start with a 1/8" drill and work my way up. Then take a jewelers file and debur. Thats how I do it anyway.
Oil slot is OK but just having one round hole is a no go for me.
Old 03-13-2019, 06:37 AM
If your dealing with a factory block look carefully at how the oil holes are drilled in the main Webb's .
You will then see that the factory drilling on the holes form a V shape that feeds the oil flow from the feed passage to the Bearing holes and the Cam Bearings.
Theses drilled V openings are where the flow restriction is when you look at things area wise and not the oil holes in most main Bearings.
Old 03-13-2019, 08:17 AM
taff2's Avatar
taff2 taff2 is offline
I cleaned up the 'V' openings with a die grinder so there is more of an oblong slot there now, radiused of course to remove the sharp edges.
Old 11-16-2020, 01:30 PM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
Does anyone have any pics of this mod?
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 11-17-2020, 12:52 AM
77 TRASHCAN's Avatar
Who is the best (or any) for King bearings?
Shut it off
Shut it off
Old 11-17-2020, 06:50 AM
The oil hole in the block with the blue dye around it is the hole that gets the oil shot. This is a FM bearing with the oil slot that has been modified to get the full shot of oil with nothing in the way.
ID:	554135   Click image for larger version
Old 11-17-2020, 07:16 AM
This is a Clevite main bearing with just a round hole like a King. Never had a King bearing though, but I see no reason you could not do the same thing with a King as I did with the Clevite.
This right here, this modification is one of the reasons I have never hurt a engine, spun a main or spun a rod bearing.
Its a old Dan Whitmore trick. He told me if I did not do this with my original Vanderville bearings i would starve the rods of oil at high RPM. I listened, it works.
Name:	DSCN1004 - Copy.jpg
ID:	554137   Click image for larger version
ID:	554138   Click image for larger version
Name:	DSCN1002 - Copy.jpg
ID:	554139   Click image for larger version
Name:	DSCN1008 - Copy (2).jpg
Old 11-17-2020, 10:29 AM
mgarblik mgarblik is offline
This is essentially what we have been doing with main bearings in any serious race application. Have had good success in 15+ years doing this pretty simple mod. For those who haven't studied Pontiac oiling circuit, keep this in mind. The angled hole from the main bearing saddle is providing the essential oiling to the mains and the rods through the crankshaft. The center hole is a riffle drilling to the cam bearings. It is way too large for serious performance use and was likely drilled at this huge 5/16" size to reduce drill bit walk and tool breakage in rapid production. The cam bearings reduce the effective size some, thank goodness. The oil feed slot in a FM bearing does at least expose some of the angular hole to direct crankshaft oiling. The bearing mods simply expose more.
Old 11-18-2020, 12:48 PM
Great info. Thanks. What about the mods to the oiling holes?
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
