Old 05-08-2023, 11:49 PM
Jromaine87 Jromaine87 is offline
Default Hood Scoop Pan
Curious what you guys think, I have a very large scoop on my car to clear my tiger intake, but I was approached this weekend at the track, was told if I sealed off the carb to scoop I could potentially gain a .10th. Now I’m pretty skeptical on that, but as everyone knows. I’m dying to get that 8.99.. Fastest 1/8 was 5.71 at 121 and 1/4 at 9.08 at 146.00 with 900 hp and 3000 pound car, I’m still determined I have something not working right. There thery was that I’m not using the cold forced air down my carb because it’s going out the back, while the car is sucking in hot engine air.
Old 05-09-2023, 12:03 AM
Dragncar Dragncar is offline
A UNI pan filler might work well for you. Seen one on a 8 second NA sbc a few years back and bought one.
Old 05-09-2023, 12:30 AM
Do you have a picture or a link I can see?
Old 05-09-2023, 06:32 AM
Scott65's Avatar
Scott65 Scott65 is offline
I've had cars where it made a difference, and also where it didn't. Those that did it was significant. 1-2mph in the quarter mile. I've also experienced an air cleaner helping significantly, 1.5 mph in a car that would run 160+ in the quarter. I believe it usually helps when it straightens/calms the air flow entry to the carb.
Old 05-09-2023, 07:52 AM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
I would put a drop base on it to smooth out the air to the carb and seal that to the scoop. Definetly worth around a tenth and a little more that 1 mph on my car
The Following User Says Thank You to Scott Stoneburg For This Useful Post:
Old 05-09-2023, 04:40 PM
UNI FRS 960
https://unifilter.com/online-catalog...otive-filters/
Old 05-11-2023, 09:00 AM
Stan Weiss's Avatar
This might be of some interest.
https://www.youtube.com/watch?v=gJwinJTVO6s
Stan
Pontiac Pump Gas List
Old 05-11-2023, 09:59 AM
Mr Anonymous's Avatar
Mr Anonymous Mr Anonymous is offline
Had my dominator sealed to the bottom of my hood using an air cleaner base and foam. Forward facing scoop. It was worth a little less than a tenth over no scoop.
I can tell you with complete confidence that your ET drops from single digits to the mid 20s when you accidentally leave the scoop plug in for a run and your sealing efforts were unexpectedly good.
oops!
Clutch Guys Matter
_______________________________________
53 Studebaker, 400P/th400/9"
64 F-85
72 4-4-2 Mondello's VO Twister II
84 Hurst/Olds #2449
87 Cutlass Salon
54 Olds 88 sedan
Old 05-11-2023, 11:36 AM
XLR8STEVE's Avatar
XLR8STEVE XLR8STEVE is online now
So after watching Mr. Vizard, does anyone use a Dominator Stub Stack along with a sealed forward facing scoop? Seems interesting....
[SIGPIC]
Steve
Old 05-11-2023, 09:00 PM
ta man ta man is offline
I used a moroso air pan that may be similar to the width...foam will be your friend to seal
Old 05-13-2023, 01:57 PM
Stan
I used a lexan scoop with no hood and picked up .14 of a second. I can’t wait to see what it does with a hood on it
