77 firebird stop light does not work
Any idea? My 77 Esprit Firebird rear stop light does not work
Fuse is okay Turn signal works Brake pedal switch is correct adjusted and I test with an wire cross connect the connector What else could it be?
1965 Bonneville 2 door coupe nightwatch blue AZ car 1965 Bonneville convertible starlight black 1966 Star Chief Coupé 1965 canandian Parisienne custome sport convertible AZ car. „Sold“ 1977 california Firebird Esprit [/SIZE][/FONT] |
The lights come on when you ran wire across terminal? That just says faulty switch or not set correctly to allow it to make contact. Make sure the pedal pulls back fully but plunger still in contact, self adjusting first use.
Have you checked the ground on the tail light harness?
Stop light
No i did not.. I checked the fuses, the switch at the brake pedal, and the bulbs.. The turn signal lights work .. The tail lights, too... The outer two are the signal and stop lights, correct, me if I'm wrong
I replaced the sealed beam front with new H4 European headlights .. anything I could done wrong that the stop lights not working ? Hm...
Stop lights
Yes, I looked at the switch... Turned in and out.. The white contact comes fully out if I push the brake pedal...nothing happened at stop lights.. I removed the connector to the switch and used an wire and connect the both contacts ..if I think correct the lights have to shine now... Nothing happened ...
It is very common for the white brake light wire to burn up where it goes into the turn signal switch plug. It get's so melted that it loses the connection. when this happens you will have all the lights working except the brake lights. Look at the turn signal switch plug
white wire for the problem. |
To close the Thread:
Yes, the white wire under column was out of place... Plug in the connector and works well now. Thx for the help!
