Old 02-17-2009, 08:58 PM
chuckies76ta's Avatar
Thanks Cliff.
Charles
Old 02-17-2009, 09:02 PM
Robert Williams's Avatar
Robert Williams Robert Williams is offline
The square flange model will accept a Holley or an AFB with the one bolt pattern. The other bolt pattern is for the early Rochester carbs as well as allowing an adapter plate for a Q-jet to bolt straight through.
"Three may keep a secret, if two are dead"
~ Benjamin Franklin ~
Old 02-18-2009, 09:36 AM
Will a q-jet fit on this one?
Charles
Old 02-18-2009, 09:47 AM
wheelspin's Avatar
Arrow
Yes, the "keyhole" shaped openings are extra large in the rear of the intake in order to accomadate the Q-jet's secondaries.
Les
Les Iden
Old 02-18-2009, 07:10 PM
Thanks Les.
Charles
Old 02-19-2009, 04:21 PM
TinjunTribe's Avatar
TinjunTribe TinjunTribe is offline
Default Measurements
Cliff (or anyone), have you taken any measurements of the runner opening at the plenum? Just wondering, right off the bat, if this manifold has larger/smaller opening (cross sectional area wise) from the plenum into the runner as compared to the 68-72 iron unit.......
What is your hypothesis Cliff?
Old 02-19-2009, 05:21 PM
Region Warrior's Avatar
I'll be watch'n for the results.
Never cared for that sharp bend in the upper passenger side runners.
And thier not as tall at the rear as factory intakes.
Although thier runner casting is alot cleaner.
Wonder how well a Pontiac intake would work if the front was as high as the rear with the stock runner size.
If i could weld iron good....
Old 02-19-2009, 10:36 PM
Cliff R's Avatar
Cliff R Cliff R is offline
I have used these intakes years ago, as Edelbrock made near identical units for SBC engines, and B and RB Mopar engines.
At the track the Mopar version was the best intake I ever ran on our 440 powered Roadrunner, running quicker ET and more MPH than a stock iron intake.
On our 1965 SBC powered Chevy II, it also delivered the best numbers at the track compared to a stock iron intake, and a later style Performer intake.
Even so, none of that testing was back to back, but in the years I owned and raced those cars, a variety of intakes and carburetors were tested, and the very best runs were from the early P4B style intakes with the wide plenum/runners.
For some reason, this intake evolved into the Pontiac and SBC narrow/taller runner Performer intake, focusing on taller/narrower runners and less overall plenum and port volume......Cliff
Old 02-20-2009, 01:55 AM
sixt8bird's Avatar
sixt8bird sixt8bird is offline
I have never heard a real good thing about the P4B and see them go for $50-$60 max. As far as I know, they were the predicessors of the performer but the performer had some upgrades that made the perform better. I dont really care for the performer either as I have always had better luck with the SD or the RPM or the TorkerII
Old 02-20-2009, 02:04 PM
AGTO8U's Avatar
AGTO8U AGTO8U is offline
I haven't ever seen a test on a P4B, so it will be interesting to see what Cliff finds out trying one with his combo.
Old 02-20-2009, 04:33 PM
Donovan Donovan is offline
It always made me wonder, since the Mopar guys and the Buick guys prefer the B4B and the mopar version over stock and other intakes. For a long time the Buick guys paid a premium for used B4B even though it moves the carb around and messes with the factory stage1 hood. Edelbrock now reproduces the B4B along side the performer because of demand.
Carcraft or Hotrod did a big intake comparison awhile back and the old 4B intake performed better than the performer as well as many others.
Did we get the only bum 4b intake..? It's possible! The factory intake is a ringer! Didn't it start off from a nascar design from the early SD?
Old 02-25-2009, 09:15 AM
Cliff R's Avatar
The intake finally showed up yesterday. I did some measuring with it, the plenum area under the carburetor is a full 1" wider than the square flange early P4B. 3/4" of that is on the drivers side only, making it at least as wide under the carburetor as an iron intake.
It appears that Edelbrock was re-designing this intake thru the years of production. At some point they went smaller with the runners and made a Performer, then taller/narrower and came up with the RPM.
I measured the P4B-QJ intake and it is larger than an iron intake in the runners, although they did this with really wide ports. The ports are not only wider, but the turns are smoother than an iron intake. It appears to provide a better shot at the head with the #8 port, which is the most restrictive on the iron intake. Time permitting I'll cc the entire intake and compare it to our ported iron one.
Pretty busy in the shop currently, but hope to port it this weekend and get it in place for some testing......Cliff
Old 02-25-2009, 12:49 PM
grandville455's Avatar
grandville455 grandville455 is offline
Awesome cliff!!! I am watching your post on this as now i have the RPM on mine... pretty close to same combos we have soo...
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
Old 02-25-2009, 05:30 PM
Sounds better then the early 4150 model i converted to q-jet with an adapter.
Been under the bench since the 80's, lol.
Old 03-08-2009, 10:27 PM
Cliff R's Avatar
Finally got around to getting the intake ready, and took some pics of the progress, and comparisons to our iron intake....Cliff
ID:	160965   Click image for larger version
ID:	160966   Click image for larger version
ID:	160967   Click image for larger version
ID:	160968   Click image for larger version
Old 03-08-2009, 10:31 PM
Cliff R's Avatar
And a couple more pics.
Interesting that the P4B measures larger everyplace than the iron intake, even depth to the runner floors down from the carb mounting flange.....Cliff
ID:	160971   Click image for larger version
ID:	160972   Click image for larger version
Old 03-09-2009, 07:37 AM
Great pics Cliff.
Charles
  #38
Old 03-09-2009, 07:40 AM
How hard is it to find the Q-jet version? Anyone have one?
Charles
  #39
Old 03-09-2009, 08:25 AM
Charles I am sure we will all be looking if this works for cliff!!!
Darby
  #40
Old 03-09-2009, 08:36 AM
lol, Ya that's my thoughts. I actually had one ready to buy, but plans changed and had to let it go.. I like the QJ version.
Charles
