Old 03-26-2009, 06:13 PM
Half-Inch Stud's Avatar
My opinion:
Original P4B design was a Squarebore-only, with subsequent poor sales, & reputation developed to overlook it.
Then Post 64 Picture #2 came out; a half-finished Spreadbore design (does not seal the Q-JET's Primary circuit) Perhaps aimed at the 800Holley Spreadbores, with Squarebore ability.
Then Post 64 Picture#1 came out, a finished Spreadbore design, with "Oops, not for Squarebore...'cause we casted a whole bunch of thooose, and they be sitting around.
I could be wrong, and would enjoy hearing "the rest of the story"
  #82
Old 03-26-2009, 06:30 PM
Donovan Donovan is offline
Well actually, there were some intermediate ones, although I don't know how you see a qjet anything in pic #2 ??? That is a squarebore only intake.
There was a P4B that had the meat of the qjet flange at all portions but was only machined for a square bore. I don't know if it was large or small runner.
  #83
Old 03-26-2009, 06:43 PM
Found it on Craigslist in Minneapolis
http://minneapolis.craigslist.org/pts/1065233873.html
LARGE runners and lacking the choke pad -weird.
ID:	163143   Click image for larger version
ID:	163144   Click image for larger version
ID:	163145   Click image for larger version
  #84
Old 03-26-2009, 06:58 PM
chuckies76ta's Avatar
Here is a pic of the one I bought..
Charles
P4B-QJ version. I think there are 4 versions of the P4B..
  #85
Old 03-26-2009, 06:59 PM
grandville455's Avatar
grandville455 grandville455 is offline
thats the one i am after! ..... i better not get sniped ,lol
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
  #86
Old 04-01-2009, 08:52 PM
Few pics of the P4B-QJ intake I bought.... This looks to be an excellent intake. The flow should match the RPM..
Charles
  #87
Old 04-01-2009, 09:05 PM
Murf'sDad's Avatar
Murf'sDad Murf'sDad is offline
Charles
Nice pickup Charles. I've been keeping my eyes open for one as well.
Stewart
1976 TA, nose converted to 1970 style, 406, ported #13 Heads, '70 iron intake without crossovers, Q-Jet - Cliff style, RARE OS manifolds, Pypes duals w/crossflow, UD 230/238 custom HR 4/7 swap cam with solid roller lifters , Hydro-Boost 4-wheel discs, 4 Speed, 3.23 posi.
“Nothing in life is so exhilarating as to be shot at without result.” - Winston Churchill
  #88
Old 04-01-2009, 09:08 PM
Nice Charles!!.. what size are the ports?.. I did end up getting the one above !!
Darby
  #89
Old 04-01-2009, 09:49 PM
This is a Felpro1233 gasket comparison. The P4B-QJ ports all measure approx 1.12x 2.03.. The torker 2 measures approx 1.03 x 2.04..
Charles
They look as good as the Torker 2..
  #90
Old 04-01-2009, 10:01 PM
Also uses the early style Q-jet bracket..
Charles
  #91
Old 04-03-2009, 10:20 AM
fbodyfan's Avatar
fbodyfan fbodyfan is offline
That is the same exact manifold i have on my car now ! I like it , no complaints about it except that it doesnt have the provisions to mount the later style of throttle/trans linkage . HEI dist fits good with room to turn ,, for awhile there i thought i was the only one with that style of manifold from looking at all the pics of everyone else`s that has posted so far ,,
  #92
Old 04-03-2009, 11:21 AM
Yea I just bought it .... I am going to open it up so i can run my q jet on it... This one appears to have the meat to do that....
Darby
  #93
Old 04-03-2009, 11:25 AM
Have you done any quarter mile testing with it?
Charles
  #94
Old 04-03-2009, 12:31 PM
fbodyfan's Avatar
i thought about doing that too , but there`s alot to cut out for the secondaries and im thinking it will need a spacer afterwards to give the airflow room to turn into the intake, and since there`s not much room now between the air cleaner and underside of the hood on my firebird , the spacer wont allow me to keep my factory ram air hood ,,
  #95
Old 04-03-2009, 12:45 PM
fbodyfan's Avatar
Charles
no , i havent , i want to ,, but my car isnt road ready yet ,,, not long after i bought the car it was obvious alot of work was needed to keep it on the road ,, and a simple brake job snowballed into ,, " well since im doing this i might as well do that while im at it " ,, kind of thing ,, and then the little side projects started happening and left the car disabled ,, im still working on it to get it back on the road " hopefully " in the next few months ,,,
  #96
Old 04-03-2009, 05:56 PM
Thanks, I know what you mean, I went into the garage 5 years ago to change the front steering linkage and it turned into a full blown restoration.. And of course lots of dollars..
Charles
  #97
Old 04-06-2009, 08:21 PM
Well Got most of the grinding done tonight so the q-jet will work on the top... just have to do some minor touch ups.. then its on to opening up the ports some.....
ID:	164553   Click image for larger version
Darby
  #98
Old 04-06-2009, 10:10 PM
That one looks pretty much the same as the QJ version. Just will except a 4150..
looks good.
Charles
  #99
Old 04-16-2009, 09:48 AM
fbodyfan's Avatar
That look`s really good !! Have you had the chance to install and test it yet ?
  #100
Old 04-17-2009, 04:53 PM
Thanks!.. No i haven't and with racing season starting may have to leave the testing up to cliff with his
Darby
