Old 10-04-2015, 10:41 AM
Half-Inch Stud's Avatar
Originally Posted by TedRamAirII View Post
1. More surface area for the belt to grip. Twice I have had cars with alternators seized and the engine would not spin. I thought the engine was bad. Disconnected the belt and all was well. Try that with a V belt.
2. With a tensioner, the belt cant be over-tightened. So bearings like water pump, PS and Alternator have a longer life. Over tightened v belts put a lot of strain on components.
3. Carry 1 belt with you. Most old cars have 3-4 belts. You know what a PITA it is to replace 4 belts, or to change 1 you may have to remove 3 ; )
4. The Multi Groove belt takes up less room. you dont need a 3 groove v pulley anymore.
HIS Rebuttal:
1. I could drop the PMD Vee AC belt, or the ALT belt, or the Water Pump only belt and still get home. Cannot do that with the single Serpentine belt.
2. I've had tensioners go squeaky. Otherwise fine. We've learned how to tighten Vee Belts to just right.
3. I've carried the "last squeaky Serpentine Belt in the trunk" but Serpentine belt replacements have been to BUY new to stop the squeak & squeal.. So the spare belt was moot, for more than several squeal-renewal cycles.
4. about the same space, Vee maybe less because of the 3- level depth PMD used for AC cars. Seems the Serpentine pulleys have a lifetime much less than the Vee pulleys, in tearm of quiet operation.
Otherwise good Thread, because I've had Serpentine upgrade on me project list for 20 years, but no implementation as yet, due to 95 Lincoln 4.6 experience with run-time to first squeal RTTFS
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct
  #422
Old 01-04-2016, 07:25 PM
1968 GTO Resto-Mod 1968 GTO Resto-Mod is offline
Originally Posted by jimmo View Post
Hey..pretty cool!
Just an update, after some initial alignment quirks were sorted way back when, my system has been running quiet and trouble-free for lots of miles. Im still diggin it every time I open the hood.
jimmo, this is awesome and i'm glad to hear it.
mine is also running running smooth- so far!
https://youtu.be/cMQFtHxR3ug
thanks for all the inspiration through your posts here.
...and thanks as well to many others who've contributed to this great thread!
i wouldn't have been able to put my serpentine system together without the knowledge i gained from this thread.
danny
  #423
Old 01-04-2016, 09:54 PM
jimmo's Avatar
jimmo jimmo is offline
Nice job Danny! I was wondering if it worked out for ya. Nice vid. Thats a really clean installation. I had to dig back thru the posts to remember how you lucked out with how that tensioner bolt spacing. Good work finding that. Glad to see it up and running.
  #424
Old 01-05-2016, 12:21 PM
AROWHED's Avatar
AROWHED AROWHED is offline
Send a message via Yahoo to AROWHED
Thumbs up
Yes, very clean and neat! How much tensioner deflection do you get when revving the engine quickly?
Considering using that NAPA 38190 tensioner you have instead of the one I used, which required a homemade welded bracket and three extra long water pump bolts.
Red\black 65 Grand Prix 467 E-head stroker, Viper T-56 6-speed, 4.10 spool
  #425
Old 01-05-2016, 04:56 PM
thanks jimmo!
i'm pushing to have the car road-ready by summer.
i'm looking forward to seeing how it all performs on the street.
i'll continue to update to this thread with my progress.
right on! thanks!
i am not revving the engine quickly.
i am in the home stretch of a 15 year, 100% complete, frame-off restoration of this GTO... and i'm not pushing anything too much.
the rebuilt 400 is barely broke in as i just started it on christmas day so it barely has 20 minutes of run time on it at this point.
the belt is very tight and i haven't observed any perceptible deflection at the tensioner under load in the 1000 rpm to 2000 rpm range.
i will continue to update this thread with my progress as i continue to move forward with the project.
thanks for your interest!
danny
  #426
Old 06-15-2017, 10:35 AM
Afdrews's Avatar
Afdrews Afdrews is offline
I'm having some issues locating the pulleys for this set up. To my knowledge there isn't a 1985 Crown vic. 1992 being the first year. Is there an updated list that I'm missing other then the one on page 4?
  #427
Old 06-15-2017, 10:42 AM
Afdrews's Avatar
In this pic is everything you need for the conversion:
Crankshaft pulley-1990 F-150.......junkyard
Water Pump pulley- 1985 Crown Victoria........junkyard
Power steering pulley- Mid 80,s Chevy truck........junkyard
Alternator Pulley- 1998 VW jetta 2.0..............junkyard
Power steering spacer plate- This has to be made from 5/8” flat stock. I chose 6061 aluminum as it is easy to work with........................can be purchased from speedymetals.com
Alt bracket spacer- 3/8” ID x 3/4” OD x 5/8” length …....can be purchased from aluminumspacers.com
Alt bracket spacer- 5/16” ID x 3/4” OD x 5/8” length.....can be purchased from aluminumspacers.com
Idler Pulley- I got mine from a subaru that just happened to be easily accessible. I made a spacer and found a suitable bolt. One can use any idler they choose as long as its spaced and fastened properly. If you choose one with a larger diameter you will need to locate it a little further from the power steering pulley than I did in my install.
Fasteners needed:
3/8”x16x6-5/8” bolt
3/8”x16x4-1/2” bolt
3/8”x16x1-5/8” bolt.........not in the photo
5/16”x18x2” bolt
Much more to follow...
Is this the updated list? Listed is a 1985 Crown vic. Could you mean 95?
  #428
Old 06-15-2017, 12:07 PM
Afdrews's Avatar
I'm guessing we are talking about an 1985 ford LTD. Sorry took me a minute to connect the dots.
Sent from my SAMSUNG-SM-N920A using Tapatalk
  #429
Old 06-17-2017, 10:03 AM
jimmo's Avatar
Yea, it was definitely all mid 80s crown vics that I pulled several from but you are also correct..."Ford LTD Crown Vic". Im guessing the "crown victoria" is the trim package.
  #430
Old 06-05-2020, 09:24 PM
The Jury's Avatar
The Jury The Jury is offline
Send a message via AIM to The Jury
Default Ford Crank Pulley cross over number
Nothing like bringing a thread back from the dead in 2020. If you're like me and working on this project it might be helpful for you to know that the part number referenced on the Ford F-250 diesel pulley is in fact an International number. I was able to cross this over to a Ford number and it comes up as F2TZ-6A312-B. So if you're looking for that pulley, plug the Ford number in and they come up on Ebay.
Hope this helps!
Derek
1968 Pontiac LeMans- The Jury
"GT...Uh-oh?!"
Pontiac 455
The Following User Says Thank You to The Jury For This Useful Post:
  #431
Old 06-10-2020, 08:08 PM
The Jury's Avatar
Bringing this one back for more info. The Ford F-250 pulley that is referenced above should only be considered for use with the shorter water pump snout in 1968 / 69. The correct Ford number for the deeper crank pulley which lines up with the 4.5 inch water pump snout is W0133-1699245. This pulley was used on 740 vehicles from 1987-1996. So options for this are plentiful. You can buy a brand new one on Ebay as of the writing of this post for $36.00
"GT...Uh-oh?!"
Pontiac 455
The Following 2 Users Say Thank You to The Jury For This Useful Post:
