power brake booster question
Group, can anyone share a photo of where the power brake booster vacuum line hooks in to the intake manifold? On my 1967 Firebird, I have an older motor that doesn't seem to have the same vacuum hookups on the intake manifold deck the stock one did.
The vacuum line goes to the baseplate of the carb, not the intake.
- Mike '69 Firebird 400 - Goldenrod Yellow, 455 +.060, '6s-7' heads, Comp Cam 276AH-10 (51-309-4), TH400, Ford 9-inch w/3.08, 800cfm Q-jet, Stock Intake, Hooker Headers, Flowmasters '68 Coronet 500 Convertible - Medium Gold Metallic, stock 318 +100,000 miles |
The Following User Says Thank You to Hikin Mike For This Useful Post: | ||
Thank you. I've got a TH350 that will need vacuum also. The vac hose from the brake booster is a good size and that carb baseplate port is much smaller.
Do you think it can handle both the transmission and the booster both? |
I assumed you had a Quadrajet. No idea how the 2-bbl connects.
What would you think about putting a tee in that big pcv line to enable vacuum to the booster?
I don't see why not.
You will need a 1/8" NPT fitting for 3/8" hose to the brake booster, threaded into the fitting already sitting at rear of base plate.
Here is a picture of a 69 2bbl engine with TH400, AC and power brakes. looking from above at the back of the carb.
My Break Away Squad 1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops) 1969 LeMans (2dr & 4dr Hardtop and a Cvt) 1969 LeMans Safari 2 seat Wagon 1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop) 1969 Catalina (3 Cvt’s & a 2dr hardtop) 1969 Ventura 2 Seat Wagon 1969 Executive 4dr Sedan 1969 Bonnie Cvt 1969 Bonnie 3 Seat Wagon (2 of them) 1969 Bonnie Brougham (4dr Hardtop & Cvt) 1969 Grand Prix SJ (2 of them) 1969 2+2 2dr Hardtop (Canadian model) |
Ok thank you for that photo north and the advice from Hikin Mike and Kenth. I guess that settles it. I would have thought that port behind the carb was too small to supply a big brake booster and transmission but if it was good enough for Pontiac, it's good enough for me
