Old 10-28-2020, 04:21 PM
lucky1 lucky1 is offline
Default Brake pedal sticking ?....
My 65 GTO has Power, four wheel disc brakes.
Sometimes when I depress the brake pedal it does not return to FULL height
And results in a very slight drag.
It sounds like it might be coming from the rear brakes.
If I pull the pedal up with my toe the drag stops.
It is slight travel in the pedal to pull it up with Hardly any effort.
What might be causing this ?
Thank you.
Old 10-29-2020, 10:31 PM
Andretti's Avatar
Andretti Andretti is offline
I'm assuming nothing's been done recently to your brake system. Sounds like a master cylinder issue, internally binding. You could try flushing/bleeding the system but replacing or rebuilding the master would be a good choice. I would go after that first as I've never seen a booster cause this sort of issue. The rear brake making a sound is understandable as your master is not releasing the line pressure.
If the booster was recently removed/serviced and the pushrod length set incorrectly, the resulting drag would be constant and not something you could relive by lifting on the pedal.
Old 10-30-2020, 08:48 PM
stevep's Avatar
stevep stevep is offline
Sounds like a sticking power booster
