my bracket is for a 71 car .i was thinking of trying to make it work but if i mount it on the block i would not be able to tighten the screw for the coil because it would be upside down
I offered before;
I might be able to help you out. How do I positively identify a post 1971 Pontiac coil bracket? I have at least two spares here.
I will also look tomorrow nite .....as we chatted today
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's |
i think i sent you a pm , anyways let me know if you have one
great i hope you got one
As I posted, when I'm out I will get photos.
So long, farewell. |
'72 has a shorter standoff than the '73-4 unit. Pre-'72 had none as they bolted to throttle bracket.
Easiest way to ID is looking at the cut out of the standoff area.
mine does not look like these .do u have one for sale
I have three here that seem to fit the bill;
Can anyone tell me if there should be any stamped numbers on them? Looking at the top flange (the end where you see the screw head): Two "A" have 3/4" flange length where the nut secures it to the intake; The third one "B" has a slightly different shaped flange, that results in 1" flange length. Looking at the bottom flange (the end that the tightening screw end pokes through): "A" centre of screw to end of flange = 1" "B" centre of screw to end of flange = 1-1/4" no PM received.
also is that a radio resistor on the bracket |
I believe it connects to the rear most intake bot;
This bot should have a stus that the bracket is slipped over, and held down with a nut; Yes that's a condenser mounted to it. I believe that the service manual shows it; I no longer have the 1973 service manual I once had, but believe it was shown in there. I am pretty sure that all points vehicles had the coil mounted the same way from 1972 through to 1974. EDIT: I corrected my above post. It's slightly out of range for this picture, but you can see it none the less.
1970 Formula 400 Carousel Red paint on Black standard interior A no-engine, no-transmission, no-wheel option car. Quite likely one of few '70 Muncie three speed Formula 400's left. 1991 Grand Am: 14.4 @ 93.7mph (DA corrected) (retired DD, stock appearing) 2009 Cobalt SS: 13.9 @ 103mph (current DD; makes something north of 300hp & 350ft/lbs) Last edited by unruhjonny; 11-30-2020 at 07:59 PM. |
The condenser is for radio noise suppression.
The left side (in your pic) has a tang that stops against the intake to keep it from rotating, a washer under the bracket supports it (I think)
It's a tiny picture, but I think this gets the idea across.
Here are pictures of the area and brackets (title of picture tells what it is of). No washer underneath that I'm aware of.
And the condenser on the side of the bracket is for radio noise suppression.
got it all worked out .thanks to all
what is the brown wire in the second photo used for
#38
Possibly TSC solenoid?
(for carb throttle)
#39
no think that is on the pass side
#40
The shaker wire is brown.
