Old 11-11-2020, 07:48 PM
unruhjonny's Avatar
Default OEM oil pressure sender
I am right now looking for an as correct as possible oil pressure sender for my car (if in doubt, see signature).
I was wondering if anyone here has any pictures of the original style unit.
If I have followed the numbers correct this is something along the lines of the part numbers as ordered;
6462137
6463727
487617
487616
499504
370801
547034
14039612
I believe that the original unit was one that looked something like this:
then it was replaced with one that looked something like this:
then later it was replaced with one that looked more like this:
I will look over the units I have on engines (it's a bit chilly out right now), and was wondering if ever these units had the part number, or an abbreviated part number stamped on them.
The couple older loose ones I have do have an "80" stamped on the hexed portion of the base just below the threaded section, and on the opposite hex face as the "80" is a four digit number.
1970 Formula 400
Old 11-12-2020, 05:39 PM
Transamric's Avatar
IIRC, the "80" refers to the sender being calibrated for an 80 lb. max gauge. The 4 digits should be the date code.
The Following User Says Thank You to Transamric For This Useful Post:
Old 11-14-2020, 04:28 PM
SD73's Avatar
SD73 SD73 is offline
They do look something like that but the base has what looks like a hex head stamped in the steel and the top has the connector held on using a nut.
Old 11-14-2020, 08:01 PM
unruhjonny's Avatar
for some reason the first image is no longer showing up.
I was guessing it looked something like this one:
1970 Formula 400
Old 11-14-2020, 08:27 PM
SD73's Avatar
That looks like the base I was describing. Here' s the other end.
Old 11-14-2020, 09:56 PM
RAJ7395's Avatar
RAJ7395 RAJ7395 is offline
Yes the one in your second post and SD73 post is the correct and highly desired sender.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int
1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int
1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int
Old 11-14-2020, 10:26 PM
Transamric's Avatar
Here's some clear pics of an original 6462137 off my white Van Nuys '71 TA. This ones dated 106-1.
Name:	1971 6462137 #1.jpg
ID:	553885   Click image for larger version
Name:	1971 6462137 #2.jpg
ID:	553886   Click image for larger version
Name:	1971 6462137 #3.jpg
Old 11-14-2020, 10:31 PM
Transamric's Avatar
And here's a few not so clear pics of original 6462137's from my blue '71 and blue '70 VN TA's. Notice these have the white plastic collar to retain the black rubber wire boot.
Name:	1970 6462137 #1.jpg
ID:	553888   Click image for larger version
Name:	1970 6462137 #2.jpg
ID:	553889   Click image for larger version
Name:	1971 6462137 #4.jpg
ID:	553890   Click image for larger version
Name:	1971 6462137 #5.jpg
Old 11-14-2020, 11:16 PM
Held for Ransom's Avatar
Held for Ransom Held for Ransom is online now
My 6462137 units ('70) were painted black and had a fiber washer (not white, but a brownish color). My 6463727 units ('74) were plated.
ID:	553892   Click image for larger version
ID:	553893   Click image for larger version
ID:	553894   Click image for larger version
So long, farewell.
Old 11-15-2020, 12:07 AM
Transamric's Avatar
I see your #4 pic is a 6463727. what is the date on that one?
Old 11-15-2020, 12:21 AM
Aus78Formula Aus78Formula is offline
Could just be underbody spray or similar since it's only on one side.
Old 11-15-2020, 08:37 AM
455hota's Avatar
455hota 455hota is offline
Here is my original oil sender from my 70 TA. I cleaned it up and it works perfectly. You can even see the original adapter fitting.
...Steve T.
"Resurrection of a 1970 Trans Am" Blog
www.455hota.wordpress.com
1966 GTO 4 speed Hardtop Alabama car (Marina Turquoise w turquoise interior)
1970 TA 4 speed Canadian car (Lucerne Blue w bright blue interior)
Old 11-15-2020, 11:07 AM
unruhjonny's Avatar
Thanks for the replies guys!!!
I can see that my question was clearly answered!!
Now I'll just cross my fingers that I have one, or can find one!!
1970 Formula 400
Old 11-15-2020, 12:31 PM
Nope. Painted all around as evidenced by the top picture.
048 3.
So long, farewell.
