Old 02-16-2024, 09:07 AM
mysticmissle's Avatar
mysticmissle mysticmissle is online now
Default crane gold rocker nuts
Anyone have a known alternative to the crane locking rocker nuts? I bought a set of almost new 1.65 crane gold rockers for my 455 and these rocker nuts (unlike my harlans sharpes,) are a little thin <.560'' or so but need a chamfer at the bottom to sit on the flat of the rocker pivot shaft, ill buy long ones for stud girdle if i have to, but will not be running a girdle
thanks in advance i need all 16
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 02-16-2024, 09:34 AM
misterp266's Avatar
If you’re looking for Crane nuts, I should have a used set in my trailer. I’ll take a look today.
Rob
" Darksiders Rule "
Old 02-16-2024, 12:48 PM
YES thanks Rob
1964 540 gto
Old 02-16-2024, 03:47 PM
AG's Avatar
AG AG is offline
I just checked the nuts with my Crane Pro Race and they are 0.596", slightly larger than yours which is strange.
Old 02-16-2024, 04:24 PM
I think my Crowers are slightly smaller than my HS I'll tray and measure one for you.
Old 02-16-2024, 04:43 PM
Jeg’s set 555-20972 are 7/16” by .580” OD.
