Old 04-08-2009, 12:22 PM
Ollie's Avatar
Ollie Ollie is offline
Yes those are the 650 brackests from Pirate Jacks also the clevis and the 4 3/4 inch threaded extension rod
Socrates,
The ball end rods came with the Hydroboost unit I bought from Ebay seller Rafel 1769
Its ok to giggle and snicker, Dont laugh and point
  #62
Old 04-08-2009, 01:06 PM
vidguy's Avatar
vidguy vidguy is offline
I got my parts from Piratejack yesterday also. Great deal.
James
Work
'67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake."
'75 Formula 400 - Daily Driver -
Running with my Home Built 455 and TH400
Details here:
http://forums.maxperformanceinc.com/...d.php?t=588372
  #63
Old 04-15-2009, 11:42 AM
vidguy's Avatar
FYI I got the 650 brackets a couple of pushrods, a coupler... and a Round eyelet end from piratejack.net here:
http://www.piratejack.net/Booster-Br...edal-Rods.html
James
Work
Details here:
  #64
Old 04-15-2009, 01:14 PM
Ollie's Avatar
Vidguy,
Did you also get the mounting plate on Ebay? Have You had a chance to do any mockup? the reason I ask is I noteced when the hydroboost is setting level as in Photo #5 in post #55 the master cylinder studs are setting at an angle as in the two photos below. I am going to remove the plate and turn it around and see what that does. Anyone else notice this?
ID:	165484   Click image for larger version
  #65
Old 04-15-2009, 01:44 PM
Old Goat 67's Avatar
Not on my setup, completely flat and level.
Side to side and front to back.
Charles
  #66
Old 04-15-2009, 09:05 PM
67cruiser 67cruiser is offline
I wanta know more to, Pirate jack, ????? Old Goat you interested in the tail lite or not?? confused??
  #67
Old 04-15-2009, 09:23 PM
Joel Koontz Joel Koontz is offline
67cruiser, follow the link in post 24 or 63 to see what Pirate Jack has to offer.
  #68
Old 04-16-2009, 08:36 AM
GS470 GS470 is offline
Ollie - Thanks for confirming which brackets you ordered and showed. I haven't had a chance to dig into my HB install yet, but hope to start soon. (I'm currently fabbing up brackets, etc... to install a Mark VIII elect fan.)
After reading your post #64, I'll have to see if the Astro van HB I bought off eBay has that tilt to it. Keep us posted on what you find out.
'72 LeMans 2Dr Hardtop
My first car, purchased in 1980
468 Stroker / KRE 315 / HR cam by SD Performance, Tremec TKO II 5spd
'96 Corvette Grand Sport (#470 of 1000 built)
Mildly modded LT4, 6spd
'07 Corvette Z06
Mildly modded LS7, 6spd
'67 Chevelle Convertible
LS6 (405HP Z06), 700R4
  #69
Old 04-16-2009, 08:58 AM
Ollie's Avatar
Ok, I got it fixed. Had to remove the snap ring and the big collar nut. The pin that holds the hydroboost looks like it was not verry prominate allowing the bracked to turn slightly when the collar nut was thigtened. Lined up the bracket and Hydroboost unit and retightened the collar, made shure nothing moved as I tighted the collar. Looks good, now.
GS470,
Take lots of photos of Your Mark VIII install. I have one to install too.
As soon as I save enougth $$$ for a DC controler.
  #70
Old 04-16-2009, 10:50 PM
Thumbs up
GS470,
Will do, Ollie. I haven't picked up a controller yet, either. Been focused on getting the thing mounted first, then I'll get it wired.
And I'm glad you got things lined up on the HB with minimal hassle.
'07 Corvette Z06
  #71
Old 04-21-2009, 01:47 AM
vidguy's Avatar
Ollie-
I haven't mocked mine up yet. I ended up finding a hydroboost locally that had a flat bracket so I traded mine with the odd angled bracket for it..
I was wondering what you meant by your pictures. I see now.. It was "Twisted" ..
I did in fact take my bracket off the first Hydroboost I had (the weird angled bracket) by using a Pipe wrench on the big nut and taking the snap ring off. It came right off. But it the nut does have teeth on the bottom flat that mates to the Hydroboost. Some type of Locking concept.
I havent mocked mine up yet, but a quick look says I'll have to drill two of the holes a bit. I can deal with that.
I do have my Piratejack brackets, coupler, rod end and threaded rods. So hopefully I'll be able to make the pushrod length fit and mount to the firewall OK.
I have to get this thing in as I dont want to put my inner fender(s) back in before that, and, I dont want to put my control arms back on until I do that... :-)
We went to Yosemite for our Birthdays this weekend so I didnt work on the car. It was super nice..
I'll let you know when I get my H/B started.
James
Work
Details here:
  #72
Old 04-21-2009, 12:44 PM
Ollie's Avatar
Vidguy:
Forget about trying to drill or file the holes on the brackets, the brackes are harder then he!!. On the new Hydroboost you got did it come with the studs and nuts. The nuts are 15mm, the studs have a striated shank like wheel studs and stick through the plate a little bit. I put a flat washer under the nut and tighten both nuts down evenly.
  #73
Old 04-21-2009, 06:25 PM
Thumbs up
Vidguy, I don't recall the plate on mine being especially hard to drill or file. It might be that some are made of different metal, but mine did not seem to be hardened steel or anything.
What is your HB off of? I thought Ollies looked like it is going to be a "bolt on" using the same basic parts you are planning to use?
It sounds like there may be more than one version of the flat plates.
  #74
Old 04-21-2009, 09:14 PM
Ollie's Avatar
Joel,
We'r talking about the # 650 brackes we got from Pirate Jacks. Thoes things are so hard all a rat tail file did was scrape off a little of the plating. The differance between the holes in the brackets and the studs is so small, when I tightened the bolts evenly, the brackes seated ok.
