I second the comment on bringing the entire assembly home & disassembling it there. The U-pull-it yard charged about $100 for a complete unit which was a great deal. The particular yard I went to had probably twenty Blazers & Bravadas & approximately half had disc brake rear ends.
Perhaps three of the vehicles I checked had the G80 limited-slip option. All the Chevy/GMC examples I saw had the GU6 code (3.42 ratio gears) and the four Bravadas I checked out all had the GT4 code (3.73 ratio gears). It definitely helps to have an RPO list in your pocket to compare with the vehicles' glove box SPID labels. 4wd rear end assemblies are a little wider than the 2wd units. A small worm gear hose clamp (like for fuel lines) makes releasing those e-brake cable clips much easier -- clamp it close to the edge and it pinches all three tabs inward just enough to pull the cable through the "hole". Hard to explain. |
1979 TATA Extreme TKO .64 Hedman elite; Pypes 2.5; Borla XS; MSD 6A; Edelbrock intake; open scoop; Sniper Q-jet; Powermaster 150; 4 core radiator/Mark VIII fan; RobbMc mini starter; subframe connectors; solid body mounts; fiberglass rear springs; poly sway bar and link bushings; 81 master; D52’s; Blazer disks; 225/60 & 235/60 17's TrueContact's; relays for PW, PDL, lights; keyless entry |
Pricing at the Pull A Part has the disc brake rear end assembly at $136.13 plus a "core charge" of $26.75. I'll need to put a pencil to the other parts and see how it works out. I would much rather pick at it at home..... I really don't want the rotors but it might be nice to have one of them to mock up the fit before I buy new ones and the old calipers would be useful as a core at the auto parts store.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
I was going to get the loaded calipers (RC10994QS and RC10993QS (staggered shocks)) at Rock Auto (cheapest place I could find for metal pistons). But they are hitting me with $56.25 for each core so it may be worth it to go get an old assembly. Plus, I would get one backing plate assembly (I need one 2WD and 4WD for staggered shocks).
Michael Oshawa built 1 option Judge basket case. 463, SD KRE 295's, CNC'd factory intake, Cliff's Qjet, Stump Puller HR cam, RARE RA manifolds, Pypes exhaust, T56 Magnum, McLeod RXT clutch, 3.42 12 bolt. 24 year project almost done... |
It does sound handy.
Lokar Universal E/Brake Cable kit...
Around $120 from Summit about 6 years ago. Sure it's a lot of money when you can score the stiff, rusted, and precurved oem cables for $20 from the yard. The Lokar's are about the size and flexibility of a Harley clutch cable, easily routed and trimmed to your correct length, and the kit comes with a machined brass block with set screws to join the front & rear cables.
Les Iden ---------------------------- '65 Buick Sport Wagon Custom, 340, T350, 3:23 '66 GTO Post/468, 700R4, 3.31 (Mike's as of 9-16) '68 Grand Prix/455, dual AFBs, T400, 2:93 posi (sold) '72 TA tribute/461, T400, 3.08, (Russ's as of 9-16) '97 Mitsubishi Eclipse Spyder Turbo, Konis, 5 speed '09 Torrent GXP, nav, Sun & Sound pkg., Bilsteins |
Plus you can sell the axles, case, and housing, etc. Or at least get $ for it at a metal recycler.
I looked on Summit and there were a lot of Lokar kits. Do you have a part number?
Many thanks to Howard (HJones1313) for the 10 page tutorial on his quest to install S10 rear disc brakes on his 70 GTO. LOTS of good info, answered some questions I had......posed some new ones that I think will be answered when I get started on my own conversion. I hope to go see what the Pull A Part might have available this Saturday AM but the 60% chance of rain may get in the way.
Look up Lokar's site. They show it. I had a quick look yesterday. Summit does carry them.
I made my 1st brake pulling run through the junkyard. Came up empty. Pull A Parts site lists 5 possible S10 donors and I found 3-4 others they didn't list. All but one started life with discs but all were picked clean.
Gotta love the humanity walking around in a junkyard.....
It's common to get beat on such specialty core parts in the Pick-N-Pulls... have to go more often, & pay attention to what days certain sections are set
In the earlier responses, just don't get the "grab the whole S10 r/e" deal, it makes little sense, unless it has a limited slip carrier in it, which will carry some resale value. Have pulled these exact swap pieces many times. Have been pulling, using, & selling factory GM rear disc swap pieces since the first '79 Sevilles hit the early Pick-N-Pulls in the late 80's. On the S10 rear disc swap, the items to pull are: -caliper mount brackets -calipers (for cores), try & buy them with nice parking brake cables attached (these will be modified) -dust shields -mtg bolts, always worth grabbing. Also, usually grab rear cover bolts & 7/16" headed u-joint strap bolts & u-joint straps. a few diff parts pulling tips... -if there is no hole & rubber insert plug in the lower portion of the rear cover from Pick-N-Pull workers draining the r/e grease, keep an eye peeled for an old '70's big Ford pickup in the yard. These often had really deep dog dish hubcaps, & they come in handy to drain the r/e grease in. Short of that, there are often other things to drain the grease in. Very few Pick-n-Pulls have enviro barrels along the rows. For r/e grease, usually, I'll find one of the next row of cars to go out, often they will be marked "Out" or Next Out", & then dump the used grease in the trunk well. when pulling the c-clip axles, install a 5/16" boxed wrench on the pin bolt for the cross shaft in the carrier. Don't try & turn this small pin bolt loose by hand with the wrench or a socket, often it will stretch & break. Instead RAP the wrench with the side of the head of your hammer. By popping the wrench CCW with the hammer, one minimizes breaking the small diameter pin bolt & it will unscrew easily. Once the pinbolt is out, the crossshaft should slide out. Bump axles in & c-clips should drop. If not, use a long thin screwdriver to get the c-clips off the axle. Usually its fairly straight forward. Good luck on next trip!
Thanks OPH!
I recommend a 6 point wrench they're not common but they are out there. I'm pretty sure this swap doesn't work on BOP axle. It has to be a C clip axle. Anyway, the 1/4 inch spacers you need you can get on Epay from S10 warehouse for $30.00. For E brake cables this simple. Take the cables from the S10. Where your two cables come together on your car, cut the pellets off. Pull your cables out of the casing from the drum side. Cut the pellets off the S10 cables (which are plastic coated but no problem) feed them into your housings. When everything else is setup pull the cables tight at the junction and mark them. Take the cables while in your original housing off the car and bring them to a cable rigging place and they will swedge new pellets on for about $15.00. Voila! Factory looking cables cheap! I did this swap on my car and the whole thing with slotted and drilled rotors, new master cylinder and pads cost me less than $250.00. They work flawlessly. My car stops on a dime! Pedal feel is excellent. I'm in the process of doing a second on of my cars right now. But check out that BOP axle thing cause all my cars are C clip.
1978 Black & Gold T/A [complete 70 Ram Air III (carb to pan) PQ and 12 bolt], fully loaded, deluxe, WS6, T-Top car - 1972 Formula 455HO Ram Air numbers matching Julep Green - 1971 T/A 455, 320 CFM Eheads, RP cam, Doug's headers, Fuel injection, TKX 5 Spd. 12 Bolt 3.73, 4 wheel disc. All A/C cars |
My axles bolt in.
After thinking about some things: 1) considering the problems David had locating one; 2) I essentially need two for staggered shocks; 3) I am currently location challenged; 4) most salvage yard parts in Minnesota are badly corroded or rusted; I have decided to just purchase new/ rebuilt parts. I know this is going to cost more, but the summer working and driving season is short and I want to get going ASAP. I’ll keep track of my costs.
Frankie, thanks for the write up on the parking brake.
#39
I got it directly from Howard.
#40
I've read a number of accounts of people doing the swap and I honestly don't think any of them mentioned bolt in or c clip. There is one conversion done on a 1969 GTO in High Performance Pontiac a while back....if it had the factory rear end that would have had bolt in axles? Is that correct? As long as the spacing on the outside (drum/disc) end of the axle mirrors where it was with drums, why would it not work?
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. Last edited by David Jones; 03-28-2014 at 02:06 PM. |
