Old 05-28-2014, 08:26 PM
David Jones's Avatar
Thanks for the move David.
  #82
Old 06-07-2014, 06:38 PM
I strolled through the Pull A Part again this morning. I found a set of Blazer parking brake cables. $16.68. Other than buying some fluid and altering the cables to fit, I should be done with the checkbook.
Just need to do it......
  #83
Old 06-10-2014, 10:11 AM
MNBob MNBob is offline
I started on mine on May 31st. So far I have removed the axle assembly, power washed it, had the tubes welded and had it blasted. A local driveline company gave me a cheap quote on the pinion seal install, so I had them do it. It should be done today. I have all the parts, but I doubt I can get this all done by the time we leave for our trip out west (Sunday). This job has not been hard; but there are a lot of pieces to it so it has been time consuming.
I loaded the pads into the calipers the other day. This system is light years ahead of what I took out of there. A modern floating pad setup with aluminum calipers.
Here are a couple of technical notes for those who may do this conversion. The banjo bolts are M10 x 1.0 pitch. The bolts I purchased to hold the caliper brackets to the E-brake assemblies are M10 x 1.5 x 30mm washer heads, grade 10.9.
1979 TATA Extreme TKO .64
Hedman elite; Pypes 2.5; Borla XS; MSD 6A; Edelbrock intake; open scoop; Sniper Q-jet; Powermaster 150; 4 core radiator/Mark VIII fan; RobbMc mini starter; subframe connectors; solid body mounts; fiberglass rear springs; poly sway bar and link bushings; 81 master; D52’s; Blazer disks; 225/60 & 235/60 17's TrueContact's; relays for PW, PDL, lights; keyless entry
  #84
Old 06-10-2014, 10:32 AM
I've been looking at ways to "swage" ends on the parking brake cables.
Anybody ever done that at home?
  #85
Old 06-10-2014, 11:12 AM
I was thinking I could braze them on.
  #86
Old 06-15-2014, 10:27 AM
HJones1313's Avatar
HJones1313 HJones1313 is offline
Send a message via Yahoo to HJones1313
Hey David, had a chance to mock up the rear axle spacers yet?
"GTO......Gas, Tires and Overdraft"!
'70 GTO convertible, 434, 4-speed
  #87
Old 06-15-2014, 05:44 PM
Not yet Howard. I did back the car in Friday with the idea I'd drop the rear end out but a bass fishing trip and Fathers Day have kept me out from under it. I should start one evening next week. I'll start a new thread about the process when I do.
  #88
Old 06-15-2014, 10:17 PM
I started out with 2 stainless washers; not even close! I quickly changed to the S10 Warehouse spacers which made it pretty good. I suppose each one of these axles is different for spacing.
I couldn't complete the job though as my right backing plate was a 4WD and it should have been a 2WD (caliper mounts behind axle). Here is a pic:
The left side is looking pretty good though:
  #89
Old 06-16-2014, 06:00 AM
HJones1313's Avatar
OK, I may beat you to it, but since you're starting a new thread I'll just wait for you. FYI, I've got another project; '77 Jag 4-piston calipers that I'm attempting to make fit on my Goat....heaven help us.
  #90
Old 06-16-2014, 06:10 AM
HJones1313's Avatar
Looks good Bob. Between you, David and I (we all have the same spacers) maybe we can get this figured out. I have a question though; can you measure the thickness of the axle brackets you're using? I'd appreciate it.
Howard
  #91
Old 06-16-2014, 06:46 AM
Howard, I would if I could, but unfortunately I am traveling to LA. Are you asking about the width of the axel tube flanges? Or caliper brackets? I will be happy to measure them when I get back in 2 weeks.
Good luck with your front project. Let us know how it goes because I may do something similar.
  #92
Old 06-16-2014, 08:10 AM
HJones1313's Avatar
Not a problem Bob, no hurry. I'm after the width of the caliper bracket that bolts to the axle flange. Have a good trip. Oh, and I think I'm going to need that luck with the the front caliper idea. I can't find anyone that's tried it, but it may be possible.
  #93
Old 06-16-2014, 08:40 AM
Howard
I'll try to measure mine tonight.
  #94
Old 06-16-2014, 09:24 AM
HJones1313's Avatar
I appreciate it David.
  #95
Old 06-16-2014, 06:23 PM
My calipers say 3/10 inch at the bolt hole.
  #96
Old 06-16-2014, 08:19 PM
HJones1313's Avatar
Thanks David. I just want to make sure we're working with the same bits. I'll check mine this week.
