Old 10-04-2022, 02:07 PM
CraigG.'s Avatar
CraigG. CraigG. is offline
Default Is cell foam necessary in 8 gallon cell with return style regulator?
Hey everybody,
The cell Foam in my 8 gallon drag tank from Summit deteriorated and filled the fuel filter when running E 85.
Do I need foam to control return fuel aeration, fuel slosh or Reducing accident fire risk?
Would these be a good replacement for the foam?
https://shop.ctstore.com/store/pc/vi...&idcategory=89
Thanks, Craig
Old 10-04-2022, 05:30 PM
Bill Eveland's Avatar
Bill Eveland Bill Eveland is offline
I took mine out and left it out when it started to deteriorate, never replaced it.
Illinois Outlaw Gassers
6.27@107
9.97@131
Old 10-04-2022, 08:24 PM
Hooter's Avatar
Hooter Hooter is offline
X2.
67 Bonneville ragtop
Old 10-04-2022, 09:32 PM
Tom Vaught's Avatar
Boost Engineer
Foam is worthless vs a simple baffle system inside the tank.
Tanks, inc tank is even better when installed in the stock location.
https://www.pinterest.com/Nuke_Perfo...el-surge-tank/
Tom V.
Old 10-04-2022, 10:13 PM
Scott65's Avatar
Scott65 Scott65 is offline
If you have some type of extension on the return where it's returning fuel below the liquid level, it probably won't aerate.
Old 10-05-2022, 12:25 PM
Dave Polichena's Avatar
Dave Polichena Dave Polichena is offline
you will be fine without the foam
Dave Polichena
Old 01-29-2023, 09:46 PM
CraigG.'s Avatar
Thanks guys - made an extension tube with 5/8 copper tubing to turn at a 90 to direct fuel to rear of sump.
Seems to work good!
Craig
