Old 02-19-2023, 01:00 PM
chiefbigb chiefbigb is offline
For what I paid for them I'm still happy with the investment. The intake bowl was pretty nice. Exhaust side needed some blending. I'm not going to modify anything else
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow.
Old 02-19-2023, 08:02 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Originally Posted by chiefbigb View Post
Pretty good stack of shims. I got the same impression on the spring situation. My rocker studs hit the installation tab for the helicoil also but I think I can break them off or shorten the stud
The exhaust Helicoil just bent enough for my studs to seat completely -but not enough room to break them off. I had studs and guideplates left over from when I converted some E heads to shafts.
I think dropping the shims down you could even possibly go a 1.9 IH. I could not put one of my big Manley springs in the pocket but it is pretty close to 1.60 OD. Not sure if the valves could handle roller spring tension or not.
Just posted flow number we got today. My buddy has worked at machine shops and is a Mopar guy and felt they looked like a decent casting, decent price and definitely a better choice than iron! Years ago they would be a $4K to flow like that.
Skip Fix
